goose neck
Old Sep 13, 2010 | 04:43 AM
scsmith42's Avatar
scsmith42
In the "for what it's worth" department, if you compare a B&W gooseneck hitch for the late model Ford, with a Reese/Drawtite version, it is clear that the Reese/Drawtite is heavier duty, especially the rails.
The B&W gets a lot of positive press, however you can turn the ball over in either one.
I've installed several; it's not that hard to do but you want to take your time with the layout so that your hole is dead center.
Spending the extra bucks for a factory installed one is a good idea, IMO.
Old Sep 13, 2010 | 05:59 PM
720Deere's Avatar
720Deere
For all you guys with anxiety over measuring and drilling the hole, forget about it! We installed a B&W in my brothers 11 last weekend and although it was more involved than my 06, it was still a breeze. Ford already provides you with a dimple or basically center punch exactly where the hole needs to be drilled. I drilled this with a regular bit, chucked that bit up in the hole saw and voila we had a perfect hole in seconds!
Once you have the B&W turnover ball setup, it's a no brainer to use their Companion hitch for your fifth wheel needs. It's the setup I have been using for more than 3 years and it will be getting transfered to my 2011 when i arrives in a few weeks.
Old Sep 14, 2010 | 12:26 PM
brandon4's Avatar
brandon4
I've had the B &W turnover and liked it, but hated climbing in the truck to flip it. For my '11 I went with the POPUP2 from a place in Kansas. You can raise and lower the ball from the ground -while sipping a Coke-. It was like 435 to my door and I installed it in about 2-3 hours. I've really liked it. The handle is in the same location as the B & W.
Old Sep 14, 2010 | 04:07 PM
rickatic's Avatar
rickatic
But will a Companion fifth wheel fit in the popup socket? That would open up a nice little niche for them.
Old Sep 14, 2010 | 09:21 PM
biz4two's Avatar
biz4two
Question
Originally Posted by PowerStrokeHD
If you have not bought your truck yet and are considering ordering... You do know that they SD's are now offered with a gooseneck/5th wheel prep package direct from the factory which includes the rails, inbed wiring hookup, laser cut rail access holes the are done prior to paint and that are finished with trim rings and close out covers for when you want a clean bed. Factory warranty as well...
MSRP on the prep kit is $370 and the gooseneck ball kit is another $250, but that can be found cheaper online either under the Ford or Reese brand...
Really? I thought the factory option was only for DRW models. Can any one confirm that the factory option is for ALL SuperDuty models???
biz
Old Sep 14, 2010 | 09:26 PM
sdetweil's Avatar
sdetweil
as I understand it, its LONG BED only..
SRW/DRW isn't affected.
Sam
Old Sep 14, 2010 | 09:38 PM
PowerStrokeHD's Avatar
PowerStrokeHD
biz
Yes, all models except chassis cabs...
Sam
Starting with production beginning November 1st the prep package will be available on short beds as well...
Old Sep 14, 2010 | 09:39 PM
biz4two's Avatar
biz4two
Thumbs up
Thanks PowerStrokeHD! Good info to know...
biz
Old Sep 14, 2010 | 10:05 PM
jstange2's Avatar
jstange2
no it will not, but reese actually makes one that works with b&w or the ones with a round hole.
http://www.reeseprod.com/content/products.aspx?lvl=3&parentid=1800&catID=1830∂=9481
Old Sep 14, 2010 | 11:14 PM
RickSo's Avatar
RickSo
Hi,
My first post here.
I went with the prep kit and goose and fifth wheel hitch right from the dealer. I had the B&W setup in my last truck but am looking to haul a heavier trailer and the B&W setup was not rated for a 20K toy hauler fifth wheel. I like the new Reese Elite/Ford setup but did call Reese the other day and ask them if they had any method to stop the banging of the hitch side to side when turning corners.
The truck is so quiet the clunking in the box was really getting to me so I took a bungee strap and tied it up.
Rick
Old Sep 14, 2010 | 11:57 PM
biz4two's Avatar
biz4two
Originally Posted by RickSo
Hi,
My first post here.
Rick
GREAT setup! Thanks for posting the pic. Welcome to FTE!
biz
Old Sep 15, 2010 | 12:30 AM
BTyner41's Avatar
BTyner41
Welcome to FTE RickSo.
Old Feb 17, 2011 | 01:14 PM
  #28
iggy2's Avatar
iggy2
RickSo
I'm getting this setup in my new truck. I see a lot of space between the hitch and the bed itself. Is this my imagination?
I was told they Ford gives you spacers fetween the bed and hitch. Is that true?
I was also told that the truck comes with rubber plugs when the hitch is removed.
Old Feb 17, 2011 | 05:38 PM
  #29
johndeerefarmer's Avatar
johndeerefarmer
When I bought my 05 SD I installed the B&W myself. Took me about 2 1/2 hours but I jacked up the back and put it on jack stands, also had to take half of the tailpipe brackets lose to make room to slide the pipe out of the way.. Was also too cheap to buy a 4" hole saw so I cut it out with a fine tooth blade in a jig saw and then with a little filing it looks factory. OH, also spend about an hour measuring and remeasuring before making that hole.
I have an F150 with ecoboost on order and I will be installing the same type in it.
I do not trust others to work on my stuff unless it's absolutely necessary
jhl3
Jun 30, 2016 08:57 PM
geniusloerts
Apr 24, 2016 08:16 PM
bigcountry1009
All Things Towing
Jul 18, 2015 08:36 PM
Unk Jim
Nov 21, 2014 01:43 PM
jtackett
All Things Towing
48
Aug 7, 2013 08:55 AM
