Adding bumper pull and goose neck wiring
Old Jul 12, 2015 | 04:29 PM
bigcountry1009's Avatar
bigcountry1009
My 2001 f 250 wiring harness has been spliced into several times to run the bumper pull and goose neck harnesses. I'd like to go to factory wiring since some of the spliced in wiring isn't working. Is there a piggy back connector availible to run the bumper pull and goose neck harnesses off of the one factory connector?
Old Jul 12, 2015 | 06:22 PM
senix's Avatar
senix
Not for your year. After 2011 they made it to run both.
Old Jul 13, 2015 | 04:59 AM
RV_Tech's Avatar
RV_Tech
Not sure if this is what you mean. It worked well for me. Pollak Custom Fit Vehicle Wiring for Ford F-250 and F-350 Super Duty 2001 - PK11893-11932
Steve
Old Jul 14, 2015 | 04:14 AM
bigcountry1009
So RV_Tech, you're running a bumper pull and goose neck harness with that setup? That's what I need if that's the case.
Old Jul 14, 2015 | 05:00 AM
senix's Avatar
senix
That would appear to be a aftermarket wiring harness for your year.
So that will work.
I would put in on the left side of the bed.
Like I have on my picture. Good spot.
Old Jul 14, 2015 | 07:20 AM
RV_Tech's Avatar
RV_Tech
So that will work.
It tees in behind the seven pin on the bumper and runs up to the bed. Yes, it feeds the seven pin for the bumper pull and the fiver hitch in my bed. Not much to installing it as it is complete including the seven pin for the bed and is mostly plug and play other than running the harness up to the bed. I have it in my 02.
If you have questions call etrailer. They have good customer service. Good luck.
Steve
Old Jul 18, 2015 | 08:33 PM
bigcountry1009
Thanks guys. That's gonna get me fixed up
Old Jul 18, 2015 | 08:36 PM
RV_Tech's Avatar
RV_Tech
Glad to hear it.
Steve
bryan23ferra
24
Jan 5, 2019 05:23 PM
SilverTop54
Apr 4, 2017 08:51 PM
droldsmorland
Electrical Systems/Wiring
Oct 9, 2014 08:13 AM
droldsmorland
Sep 8, 2014 10:14 PM
1cutter1
Nov 13, 2001 07:22 PM
