Dealer wanted $695. I went down the street and found two aftermarket places that would install it for $475. So I picked the one that was closest to home and they also got to do my spray in liner while they did the hitch. So out the door for both for under $1000.
You can buy the B&W for $399 and install it yourself. Takes about an hour. But you have to be brave enough to use a hole saw on your new truck!
I have the B&W Turnover Ball setup on mine. It was $509 installed.
Does this include the wiring/plug in the bed of your truck?
I'm wanting to get away from the bumper pull equipment trailer so I'm new to the gooseneck world. Seems like a smarter thing to do from experience and what I read.
A local trailer shop quoted me $550 for the 1111R B&W turnover ball and installation. Another $120 for the electrical wiring/plug in the bed.
I haven't asked my dealer. I assumed they would be more and didn't even try.
It's cutting into my truck that makes me nervous...I don't work on vehicles for a living so I would rather have someone else do it who does this daily. B&W Custom Truck Beds, Inc.#
I have the reese elite rail with gooseneck coming sometime next week so I will be able to fill everyone in on how easy of an install it is. Four 2 1/2 inch holes for fifth wheel. One slightly bigger for the gooseneck and one in the side of the bed for the plug. Lots of cutting but I love it.
My understanding is it is all just bolt in other then cutting the access holes. Should be just like factory when you are done with the exception that they use a laser to cut their holes...
thanks!
while I am asking.....are you happy with the hideaway ball?
I have never had a hideaway but would likely go with the option for a new truck.
the advantage of the permanent ball is my wife doesn't have another thing to mess with when hooking up and hauling.
KPER- with a gooseneck set-up....you really don't know the trailer is behind you. no sway from a center point of access like a bumper pull, easier to turn and back in tight spaces and much easier to hook-up for my wife.
in fact- I had to have some trailer work done recently, mechanic asked if she needed help and she said...."no all set"...... and she got the applause of several guys in the shop when she drove up then backed our horse-trailer between two vehicles.
thanks!
Ha, every time I see an SD pulling a gooseneck horse trailer there is a woman driving. They can put a mean whuppin on those things.
You doing this on a long bed or a shortie?
Long beds only for me. It actually looks easier to put in than the b&w in the old dodge.
Question regarding goose neck ball.
Are you having it installed via the dealer or aftermarket?
What are your costs for either?
thanks
If you have not bought your truck yet and are considering ordering... You do know that they SD's are now offered with a gooseneck/5th wheel prep package direct from the factory which includes the rails, inbed wiring hookup, laser cut rail access holes the are done prior to paint and that are finished with trim rings and close out covers for when you want a clean bed. Factory warranty as well...
MSRP on the prep kit is $370 and the gooseneck ball kit is another $250, but that can be found cheaper online either under the Ford or Reese brand...
I was working out of state when I bought my truck. I had no shop available to tackle the install. It did not include the in box wiring, They wanted $100 more for that option. It took an experienced guy about 2.5 hours to install the hitch. I do not have a goose neck trailer so but I do like the clean box floor when I remove the Companion 5th wheel hitch. I went with the B&W because my previous truck had it installed when I bought it. I had purchased the Companion for that truck. I like the Companion hitch so much there was never a thought about going another route.
Regards
How does the companion work with the new bed since they removed the coragations? It made me real nervous since there is only six or so inches in the middle for the companion to actually rest on.
Have you ever had any problems with your u-bolts or the draw down bolt stripping when torquing to b&w specs? I never had a problem with mine but my buddy is on his second draw down and third set of u-bolts.
