T-Stat?
Old Sep 10, 2010 | 04:22 AM
Big_Dom's Avatar
Big_Dom
T-Stat?
Okay, so I'm replacing the thermostat in my 1976 F-150..(the previous owner had taking it out). So there wasn't one to go by, and I'm unsure if I put it in correctly. And I've looked on many forums, the only problem is I'm a very visual person. I guess the only thing I need to know is.. does the spring go towards or away from the engine bay? Any pictures or comments that may be useful?
Thank you.. Big Dom (The Hulk)
Old Sep 10, 2010 | 08:29 AM
704 dentside man's Avatar
704 dentside man
FlowKooler 333-180 - FlowKooler Robertshaw Series High Performance Thermostats - Overview - SummitRacing.com
First off...I'd spend the extra coin to get a Robertshaw tstat^^^.
Secondly...You drop in a tstat, exactly as the one in the summit pic is positioned:
Summit Racing SUM-360180 - Summit Racing® Thermostats - Overview - SummitRacing.com
Also be sure to be careful on the waterneck. First time I ever did one, I ended up cracking the cast neck.
Old Sep 10, 2010 | 08:50 AM
fmc400's Avatar
fmc400
MSEE
Most thermostats are marked; for example some say "TO RAD" to identify which side faces the upper radiator hose.
Old Sep 10, 2010 | 09:48 AM
jsutton's Avatar
jsutton
Just a little FYI and trick I read about and do now, drill a small hole in the flat part of the T-stat to let air escape as you fill the coolant, so you don't end up with a big air bubble trapped in there behind it.
Old Sep 10, 2010 | 10:26 AM
Fordby4's Avatar
Fordby4
jsutton,
I had a 84 Ford Bronco ll that I repalced the water pump on ,it air locked on me, after several failed attempts I called an old mechanic who told me to install a flush tee fitting on the heater hose and fill the system that way, never had any other issues with it.
Old Sep 10, 2010 | 10:40 AM
berry1234's Avatar
berry1234
I just run the truck with the radiator cap off for a while. Have not had a prob. I use Motorcraft thermos. You can find them, just look around. Cost me $6 or so.
Big_Dom
Mar 31, 2011 11:39 AM
Big_Dom
Apr 13, 2010 10:07 AM
domdel63
Mar 29, 2010 09:18 PM
Big_Dom
Feb 8, 2010 05:18 PM
Jesse R
Garage & Workshop
Feb 8, 2005 02:30 PM
