Are Load Leveling Air Bags generally a universal fit
Old 09-09-2010, 09:07 PM
60RatRod's Avatar
60RatRod
60RatRod is offline
I am looking to get some used load leveling air bags and was wondering if they are generally a universal fit between most Body Over Frame trucks? The reason I ask this question is I never installed or owned air bags and most people are advertising by make and model truck. I am trying to understand why make and model makes a differance when all trucks generaly have leaf spring suspension, so why would it make a differance if the air bags are off of say for example a "Toyota Tundra" would'nt the air bags still work? I mean seriously how much differance could there be. Anyone have pics of their load leveling air bag install?
Thanks in advance Dan
Old 09-09-2010, 09:42 PM
Riffraff Diesel's Avatar
Riffraff Diesel
Riffraff Diesel is online now
PREMIUM SPONSOR
It makes a difference because of distance from frame to spring pack, mount attachment design, bag weight rating, bag design for suspension articulation ect. If you need help finding a set let me know, I am happy to help.
Old 09-09-2010, 10:06 PM
Stangrcr1's Avatar
Stangrcr1
Stangrcr1 is offline
Many companies will use the same airbags and make slight adjustments to the brackets.
But the better companies will have special bags and brackets for each model of truck.
You may be able to make Tundra airbags fit your PSD, but that does not mean they will hold the weight they are rated for.
Old 09-09-2010, 10:19 PM
60RatRod's Avatar
60RatRod
60RatRod is offline
Thanks Clay,
Budgets tight this month and was looking for some used ones like from Craigslist. I can weld and fabricate thats why I asked the question. In other words if its simply a bracket issue I can probably modify it myself and make it work. Only problem is I have never seen a set of air bags installed, really need to see some pics to see how entailed the installation actually is.
Old 09-09-2010, 11:35 PM
JockD's Avatar
JockD
JockD is offline
If you are looking for used bags, the Firestone Ride-Rite kit #2071 is proper for your truck. This set mounts on the outside of the frame, so it is not compatable with a 5th wheel hitch. It also needs four 3/8" holes drilled in the side of the frame on each side to mount the bags. This kit was used on F150 and F250 pickups for 20+ years (1969-on), as well as many Dodge pickups (1969-2001 or 2002) and Chevys (1973-1987).
I believe the #2330 kit is the modern inboard mount style which can be installed without drilling any holes. It works with the 5th wheel hitches.
When buying a used kit you may not get some of the mounting parts, since some parts are not used on many applications. Also, you will have to get new nylon tubing and perhaps some of the end fittings.
There are some good deals out there on new kits. I paid $170 for a brand new 2071 kit because most customers now want the "no-drill" kits that fit the 5th wheel hitch and the dealer had too much dust covering the sealed box!
Old 09-09-2010, 11:49 PM
60RatRod's Avatar
60RatRod
60RatRod is offline
Thanks Jock,
You don't even know how much headache you just saved me. I am new to the 5th wheel and its the reason I need load leveling air bags. So needless to say I now know there are two kits ( one for 5ers and one for no 5th hitch)
Thanks Dan
Old 09-09-2010, 11:59 PM
JockD's Avatar
JockD
JockD is offline
Dan, Does your hitch mount on the outside of the frame over the rear axle? If so, you will need the inside mount kit. If the frame is not obstructed over the axle, the 2071 kit may work. It was the only kit Firestone made for Fords for years.
Old 09-10-2010, 09:35 AM
bobbyrjw's Avatar
bobbyrjw
bobbyrjw is offline
Dan, I did the Firestone bags. I have a fifth wheel hitch and they fit in great.
You buy for the truck so you don't have to do a lot of drilling.
I took a few pictures this morning, but it is raining and they are the best photos. You may get the "picture" of how they fit.
Old 09-10-2010, 10:08 AM
60RatRod's Avatar
60RatRod
60RatRod is offline
sweeet, thanks for the pics bobby. helps a lot.
Old 09-10-2010, 12:54 PM
Mike F250's Avatar
Mike F250
Mike F250 is offline
There was a good write up with pics a few months ago. I'd post the link to it but I never have any luck with searches...
Old 09-10-2010, 01:26 PM
60RatRod's Avatar
60RatRod
60RatRod is offline
Thanks Mike, I did'nt know that. I'll have do some advanced searching and see if I can't find it.
Old 09-18-2010, 11:28 AM
60RatRod's Avatar
60RatRod
60RatRod is offline
Thanks to Clay, he helped me find and I ordered up a set of Firestone P/N 2330 Air Bags. Here's a pic of what the kit includes.
Old 09-19-2010, 08:48 PM
60RatRod's Avatar
60RatRod
60RatRod is offline
Here's the run down on how easy the kit install went
Remove Jounce stop but save spacer for reuse on top bracket
Top bracket install easy with no drilling and one 3/4" nut and bolt using existing hole in frame
Top bracket inside frame view ( washers are used if the braket doesn't fit flush against the frame)
air bag attaches to top bracket using a single 3/8" bolt and alignment pin that lines up with top
bracket
heat shield is provided in kit for exhaust side air bag
lower bracket is installed after air bag is secured to top bracket
lower bracket has three adjustment settings for 4 and 2 wheel drive trucks
air bag is bolted to lower bracket then bracket is secured using a U bolt and a strap clamp
Air hose is attached and routed to rear bumper
Add a minimum of 5 PSI and you're ready to roll.
Old 09-19-2010, 09:18 PM
gradyc's Avatar
gradyc
gradyc is offline
wellhead
Dan, nice write up and great pics.
97-psd
02-25-2017 08:43 PM
ireding
02-07-2017 08:52 AM
pirate4x4_camo
11-30-2015 04:38 PM
carrfamilynj
24
01-10-2014 03:17 PM
O SEA D
13
09-21-2011 06:18 PM
Quick Reply: Are Load Leveling Air Bags generally a universal fit
