Sponsored by: Auxito
please help. brake problem.
Old Sep 12, 2010 | 01:18 PM
Dave G.'s Avatar
Dave G.
Might want to check into a brake proportioning valve if you try removing the RABS. Without the valve its possible to lose most of your braking if you have a serious issue at the front or rear.
Dave
Old Sep 12, 2010 | 01:42 PM
93 mix 'n match's Avatar
93 mix 'n match
did they change the brake systems that much? i remember taking RABS out of an older ford and it was pretty easy.
Old Sep 14, 2010 | 05:36 PM
FlyByNight's Avatar
FlyByNight
Another thought Louis. I hope that clicking and pedal drop wasn't the master bypassing itself because of the restriction. This sounds like what is happening to me, and I personally would replace the master along with whatever is causing the restriction. Good luck with whatever you do.
hairyboxnoogle
30
Nov 6, 2013 07:59 PM
98SVTCobra
May 19, 2011 08:09 PM
grady420
15
Apr 1, 2009 12:19 PM
dreadhed
Sep 9, 2006 03:44 PM
