Turbo "farts" under moderate acceleration??
Old 09-07-2010, 11:10 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
diesel-fitter-bum01 is offline
Sometimes not all the time, when I'm accelerating the turbo will blow off it's boost. Hence the turbo farting noise. Do I need to tighten up my wastegate? Building around 30lbs of boost. Not a WOT run just above average driving. Thanks
Old 09-07-2010, 11:23 PM
nissandoc's Avatar
nissandoc
nissandoc is offline
First thing I would do is tighten all the clamps on the boots on the IC tubes.
Old 09-07-2010, 11:24 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
What about an overboost eliminator? If you are achieving over 22PSI at the Map sensor then the truck defuels? Although I do believe Jody tunes around it, so neverminds, you could always disconnect the red line and see if it still does it?
Old 09-07-2010, 11:29 PM
diesel-fitter-bum01
Already checked for leaks in the boots. I have a boost fooler. Haven't tried unhooking the wastegate yet. But will.
Old 09-07-2010, 11:43 PM
Stangrcr1's Avatar
Stangrcr1
Stangrcr1 is offline
I have been alongside ricers and when mine has "farted", they get a big gulp of diesel smoke. Usually at the 3-4 shift. I haven't minded it.
Old 09-08-2010, 12:02 AM
diesel-fitter-bum01
Why wouldn't it do it on a wide open throttle run though.
Old 09-08-2010, 12:09 AM
Stangrcr1's Avatar
Stangrcr1
Then it is either too much fuel or not enough.
My turbo is modified though.... And special tuning.....
Old 09-08-2010, 12:17 AM
diesel-fitter-bum01
I have a gtp38r bb turbo. Dp tunes. Just started happening since the new turbo
Old 09-08-2010, 12:27 AM
Stangrcr1's Avatar
Stangrcr1
Then maybe you need to cal Jody instead of asking us.
We don't know chit compared to Jody as far as what is in your chip.
Yeah, why are you asking us?
Old 09-08-2010, 01:12 AM
diesel-fitter-bum01
Because there is a lot of experience on here
Old 09-08-2010, 01:17 AM
Stangrcr1's Avatar
Stangrcr1
Point being, call Jody.
Old 09-08-2010, 08:01 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Sounds like your 38r is surging to me. There is a "sweet" spot usually where they'll do it. Not sure on the 38r, but the stock 38 does it around 1800rpm under acceleration. Assuming you don't been during shifts, which is fairly normal especially with the 6637.
Old 09-08-2010, 11:06 AM
diesel-fitter-bum01
Thanks Joe, just wondering if it was normal or if I need to tighten up my wastegate.
Old 09-08-2010, 11:13 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
You might have to. With stock injectors & a 38r, you won't need to bleed off any drive pressure. It will be okay up to 40psi, which you'll never get to with stock fueling. Did you adjust it at all when you put it in? Most folks with stock sticks tighten it all the way down, so if you haven't, that would be step #1...
Old 09-08-2010, 11:20 AM
diesel-fitter-bum01
Na I didn't mess with it Joe, too excited to put it in. Haha. Cool guess I have a weekend project.
dan9812
1999 to 2016 Super Duty
09-24-2016 07:18 AM
DawnPatrol
01-11-2016 09:37 PM
Kelceykzk
10-08-2013 11:46 PM
ROBBINthaHOOD
12-01-2011 06:33 AM
eddiedebb
10-20-2010 07:27 PM
Quick Reply: Turbo "farts" under moderate acceleration??
