1997 e40d valve body
Old Sep 4, 2010 | 02:59 PM
kris81's Avatar
kris81
i got a 1997 e4od traanssmision i found three ***** for my valve body in mt tran pan cause someone didnt tightin the valve body down i need to know where they go so does anyone know where i can find a diagram for this
Old Sep 4, 2010 | 03:23 PM
DRRXR's Avatar
DRRXR
Bump
Maybe this bump will help.
Complete E4OD High Performance T
Ford Bronco And F-150 Links - E4OD
TransTec Transmission Selector for E4OD
Old Sep 4, 2010 | 05:06 PM
kris81's Avatar
kris81
what i need is a diagram of the main valve body
Old Sep 4, 2010 | 08:39 PM
MADVAN's Avatar
MADVAN
Its Impossible to happen. Someone was inside the trans.
The ***** can only fall out if someone removes the vb from the core.
Locations and size of ***** has to do with a combo of parts used.
1- Case Code (E9,FO,F8)
2- Plate ID
E9 Case = 89 has hole 90 no hole
FO Case = 90 has hole, 89 no hole
FO Case = 96 has slot
F8 Case = No slot "M" This is a 4R100 case.
3- gasket ID (matached to same case id)
4- VB Code (E9,FO,F6)
5- Acc body (E9,F6)
If its a all orig 97 it should be
1= FO
2= plate with slot
3= has slot
4= F6
5= F6
Calls for 8-5/16 checkballs
Bill
Old Sep 4, 2010 | 10:45 PM
F350-6's Avatar
F350-6
Look at the instructions in this thread. https://www.ford-trucks.com/forums/7...l-article.html
They show the location of the check ***** in the main valve body. My internet at home is way too slow to watch a video right now, and I don't remember if the video covers the check ***** (it leaves a lot of stuff out, including the messy, always dripping ATF that you have to fight) Install Assistance Videos
Click on the E40D / 4R100 video and hope they show that part.
Old Sep 4, 2010 | 11:36 PM
kris81's Avatar
kris81
thanks f350-6 that helped alot but i also found out you can go to transgo and find out everything about this trans and how to fix all the problems its got
Old Sep 4, 2010 | 11:38 PM
kris81's Avatar
kris81
another thing can someone tell me how to fix my od it want cut on it just flashis off the whole time
Old Sep 4, 2010 | 11:58 PM
fordpride's Avatar
fordpride
If the OD is flashing the it has codes needs to be hooked to a scaner
mytimeistoday
Feb 9, 2017 11:06 PM
Brian Donoghue
Apr 17, 2016 04:29 PM
Rolait
Sep 17, 2010 02:00 PM
'88 E-350
Sep 15, 2010 12:41 PM
skinsey
Mar 2, 2004 09:17 AM
