Making metal clones from an original Merc Tailgate?
Old 02-06-2012, 02:33 PM
52 M1 Kootenay Kid's Avatar
52 M1 Kootenay Kid
52 M1 Kootenay Kid is offline
If you had an original Mercury Tailgate in perfect condition would it be possible to have metal ones reproduced by means of molds etc.
Is this to costly? What would be involved?
I think mine is a female,does anyone have a male Merc tailgate? Maybe we could do it this way!
Cheers
Old 02-06-2012, 03:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
They are stamped not cast. There are ways to make dies for low-production runs but the tailgate is pretty thick steel so the dies are still going to be hefty. If you could buy Ford tailgates from someone who is making them, but get them before they stamp the FORD onto it, it might be reasonably priced, but I doubt there is much demand.
Old 02-06-2012, 04:14 PM
Greg M-47's Avatar
Greg M-47
Greg M-47 is offline
Are the '51-'52 Mercury tailgates different than the '48-'50 tailgates ? I know the M-68 are a different beast but I'm not up on the '51-'52. Like I said in an earlier post it is easy to turn a Ford tailgate into a Merc one IF you have the name plate to spot weld in.
Northern Classic pickups were making Mercury tailgates.
Greg M-47
Old 02-06-2012, 07:24 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,451 Likes on 1,398 Posts
The 51-52 Merc tailgates are different from the earlier ones. There's the latching differences that came with the bed style change in mid-50, same as the Ford, and the center raised section is wider than the outer two, where the earlier model has 3 even 'squares' since it was essentially a modified Ford gate. The Mercury got it's own stamping and the letters are larger and stamped into the gate itself, and no longer an add-on piece.
The Mercury tailgate that Northern Classic sells is for the 53-68 models. It's $425.
Old 02-06-2012, 07:41 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Received 2,059 Likes on 804 Posts
There's a thread on the HAMB board about shop press tooling. In one post a guy was stamping the Ford script into sheet metal. If you were ambitious enough you could stamp Mercury panels to be welded into Ford tailgates but that would take a lot of work, I don't if it'd be worth it.
jmadsen
10-17-2022 05:56 PM
Harrier
30
01-08-2019 07:04 PM
6t6merc
11-12-2013 07:20 AM
Homespun91
01-01-2004 11:40 AM
Chuck 6083
02-12-2002 12:22 AM
Quick Reply: Making metal clones from an original Merc Tailgate?
