pcm # help
Old Sep 3, 2010 | 01:42 PM
Joe28443's Avatar
Joe28443
Joe28443
pcm # help
am trying to locate the pcm# on my Ex and got a question. I have tried looking at the instructions on their website and from what i can tell it dont look like what i got> I removed the kick panel and there is a black box hold ing what looks like the pcm. I took off the 10mm nut and went under the hood. from what i see the other side of that (under hood) looks like there are three harnesses hooked to that with 2 nuts. Is that what I take off to check the code? Sorry if this sounds like I'm an idiot but I am only being myself
Old Sep 3, 2010 | 02:01 PM
riverrat41's Avatar
riverrat41
Sorry I do not have a pick but see if this helps.
It is located back under the ebrake pedal.There will be two 1/4'' screws that hold a black cover on.Take those out.Go under the hood and on the drivers firewall there will be a 10mm(i think) bolt right in the middle of a wiring harness.Loosen that bolt all the way(it may not fall out though).Go back into the cab and pull out the PCM.You will see the numbers then.
Old Sep 3, 2010 | 02:28 PM
Joe28443's Avatar
Joe28443
Joe28443
you mean that bolt that holds on my license plate?? LOL that thing has got to be long. I turned on it for 10 minutes and it still would not come out. i am giving it a rest, i think i know what i am ding but when its 97 degrees. i cant be outside that much without haveing a heatstroke lol.
Old Sep 3, 2010 | 02:35 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
The bolt stays on the connection. lol Once it's loose, pull on the connection and it will come off.
Old Sep 3, 2010 | 07:56 PM
rbaker6336's Avatar
rbaker6336
Don't forget to put your keys in your pocket or some safe place (not the ignition) before pulling the PCM
Old Sep 3, 2010 | 08:28 PM
Franko72's Avatar
Franko72
Molon Labe
Yep keys out....pull down and in, its a bear but it comes out.
Old Sep 4, 2010 | 02:31 PM
Joe28443's Avatar
Joe28443
Joe28443
I am out here now trying to pull it out. I think I got the bolt loose enough! I guess i am scared i am gonna break something. When u said down and in does that mean the pcm (inside) or the plug (under hood)
Old Sep 4, 2010 | 10:40 PM
Franko72's Avatar
Franko72
Molon Labe
Sorry so late with a reply, but I meant the PCM in side the truck. Im sure you have it out by now. Its difficult to explain, just wiggle, it will come out.
Old Sep 5, 2010 | 07:21 AM
megawatt00's Avatar
megawatt00
This might help you a bit
http://www.dp-tuner.com/wordpress/wp...stallation.pdf
Old Sep 5, 2010 | 04:41 PM
Joe28443's Avatar
Joe28443
Joe28443
I finally got it off and just placed my order @ DP. Now what sux is they are closed tomorro
w and I got to wait an extra day
tpntx
Apr 18, 2012 04:42 PM
shaneinga
Mar 16, 2012 01:59 PM
emery72
Mar 16, 2012 11:18 AM
hotrodpainter
Jun 5, 2010 07:42 PM
glasseater
23
Sep 9, 2007 12:22 PM
