PCM istall problem
Old Jun 2, 2010 | 06:39 PM
hotrodpainter's Avatar
hotrodpainter
6th Gear
PCM istall problem
2004 e 350 6.0 turbo diesel I have a rebuilt PCM from AES the old PCM had a 602 code and the van still ran but had some issues . ok i disconnected the battery completely before i installed the new PCM put everything back together checked under hood fuses. i have power but no start power and the fuel pump doesn't operate. but glow plug indicator operates as well . also it i hook up the livewire to read the PCM it doesnt see the PCM ok what am i doing wrong
Old Jun 3, 2010 | 01:24 AM
cartmanea's Avatar
cartmanea
Do they advertise it as already being programmed? You may need to get it flashed.
Old Jun 3, 2010 | 10:40 AM
hotrodpainter
6th Gear
thanks for your replies . they said it would be programed to my truck but may need flashed i guess that could be the problem i was hoping it would be something simple and i guess that is
Old Jun 5, 2010 | 07:42 PM
hotrodpainter
6th Gear
well the truck is at the dealership and they are not having much luck .
they are not getting a connection to the pcm either
boy am i going to pay
kbarbee95
Feb 2, 2015 07:00 PM
Codyscee
Modular V10 (6.8l)
Aug 27, 2014 03:39 PM
cajunbull61
2004 - 2008 F150
Feb 17, 2009 07:01 PM
jpucovsky
Electrical Systems/Wiring
Nov 2, 2008 08:37 PM
cleatus12r
32
Sep 5, 2008 09:07 AM
