Bear claw latches
Old Feb 18, 2003 | 09:33 AM
tgregoire's Avatar
tgregoire
Bear claw latches
Any of you guys know of a donor car which uses bear claw type latches which are similar to all the after market types? I have access to a boneyard to get parts cheap and don't want to have to hunt around in two plus feet of snow on saturday try to find some.
Also, anyone know of a selonoid such as a power lock selonoid which activates when power is applied and retracts when power is cut from it? I'm doing suicide doors and want to make a couple of safty latches so the doors cannot pop open while I'm driving. I was thinking of activating it when the ignition key is turned on and deactivating when the key is switched off.
Thanks for your help.
Old Feb 18, 2003 | 08:41 PM
fatfenders's Avatar
fatfenders
Bear claw latches
Greg
I don't think bear claw latches are available in a stock application but they are very reasonably priced aftermarket.
Old Feb 19, 2003 | 07:52 AM
56efffie's Avatar
56efffie
Bear claw latches
I do know that if you put continuous power to a power door lock solenoid it will burn up (past experience)
Old Feb 19, 2003 | 09:22 AM
tgregoire's Avatar
tgregoire
Bear claw latches
I also believe that the selonoid would fry, I was just using that as an example. I was hoping someone would know of a vehicle which would use a selonoid which functions as I described. I can't think of one off the top of my head. I'm sure I could do something if I designed a circuit to control it but I thought there may be something already designed for that use.
Old Feb 19, 2003 | 04:17 PM
jniolon's Avatar
jniolon
old and in the way
Bear claw latches
there are some manual pin type door latches ... seen them in Street Rodder for sure... lots of that type door in 30's cars...
check some of the vendors in Street rodder... usually in the billet boy stuff..
john
KidShalene
Oct 26, 2010 11:58 AM
Flathead Meltdown
Jul 5, 2010 06:17 AM
Henry Burnside
Mar 22, 2008 05:46 AM
svooom
Jul 13, 2006 01:58 PM
