Bear claws
Old Mar 19, 2008 | 10:02 PM
Henry Burnside's Avatar
Henry Burnside
Bear claws
Hi , I'm new to forum so here go's. I just installed Large Bear Claw latches on my 48 Ford pickup, instead of putting the latches on door and latch stricker on cab pillar, I drilled the alignment pin plate off cab pillar welded the 4 little holes then drilled pillar for bear claw latch. The claw fits great leaving lot of room for door acuators and keyed cable lock under cab. The stricker pin is put on door stricker leaving no pin to catch pants on getting in. Will put pictures on this weekend.Henry
Old Mar 20, 2008 | 11:08 AM
sparky's Avatar
sparky
Cool, nice idea. I am awaiting the pics....... bear claws are on my to do list .......... which is several pages long and growing every day
Are they after market latches...or robbed from the auto graveyard?
Old Mar 20, 2008 | 12:11 PM
homade's Avatar
homade
Welcome to FTE but we gotta have pics, cause some of us can't read.
Old Mar 20, 2008 | 02:04 PM
mt54's Avatar
mt54
Welcome to FTE Henry... I also liked the Idea of the latch in the pillar, here are a few pics of my installation.
https://www.ford-trucks.com/user_gal...122861&width=0
Old Mar 20, 2008 | 08:46 PM
CIAF's Avatar
CIAF
Hi Henry, Welcome to FTE. I hope you hang out a while, we love new ideas and the pictures to go with them ideas. And btw, we love pictures.
Jon
Old Mar 20, 2008 | 09:09 PM
NDspeed's Avatar
NDspeed
neat i like the new age stuff
Old Mar 21, 2008 | 01:24 AM
51ford fan's Avatar
51ford fan
I did the same the pictures are in my gallery if your interested. Only real problem I have had is I removed the orginal Dove Tails from my pilars and put the Bear Claws there. This has caused my doors now rattle over bumps. I have thought about replacing them but sense my 51F1 is my only means of daily transportation it's been hard to take the time to work on it.
Old Mar 21, 2008 | 02:30 PM
53fatfndr's Avatar
53fatfndr
I wanted to put my latches on the pillar instead of the door as well. While I ended up installing my striker pin on the pillar, I don't catch my clothes on it. My actuators fit great in the door, I just didn't like having to run wiring in the door jamb. Post the pictures up when you get a chance.
Old Mar 21, 2008 | 02:57 PM
1Digger's Avatar
1Digger
This might sound dumb, but how do you get out once you're inside? Do you have to use a keyfob?
Old Mar 21, 2008 | 05:06 PM
Henry Burnside
Yes I'm putting elec allthe way so keyfob will open door from outside but inside will have a switch next to window switch to open from inside and an keyed lock with cable that can open from under cab above running board.
Old Mar 21, 2008 | 05:33 PM
merc546's Avatar
merc546
So what happens when your inside and the battery dies?
Old Mar 21, 2008 | 09:31 PM
51ford fan's Avatar
51ford fan
Welcome to the Forum Henry, I just slide my hand down along the back of the pillar and catch the lever and pop them open. I plan on installing a mechanism like the orginal Corvettes use to open the doors when I get a headliner installed.
Old Mar 22, 2008 | 05:46 AM
sarmentrout's Avatar
sarmentrout
Bear Claw
I just installed a set of Altmans bear claw latches on my 56 (made for 56 only). One quick cut and bolt them in. Works like a charm! I also put a set of the new door rubbers on it. They are great. Soft like new car rubber.
Steve
KidShalene
Oct 26, 2010 11:58 AM
kevkel
28
Nov 1, 2006 01:24 PM
svooom
Jul 13, 2006 01:58 PM
58hotrod
Dec 26, 2003 11:37 PM
