Bear Claw Door latch install - questions
Old Oct 26, 2010 | 09:19 AM
KidShalene's Avatar
KidShalene
48-52 F1's - Questions for anyone who's installed bear claw latches in their truck.
I have a set of small latches purchased yrs ago, but would like to now use power bear claw latches if possible.
Sitting here at work I was googling for the best price and found an install write up that warned of the space available for these power latches.
Seems the window channel could be an issue for the power latches, anyone installed any of these power latches in an F1 that would like to share their experience.
Old Oct 26, 2010 | 09:54 AM
Lakotas53's Avatar
Lakotas53
You have enough post now to do a search. (25) there are numerous post on the subject. Here are a couple.
https://www.ford-trucks.com/forums/9...r-handles.html
https://www.ford-trucks.com/forums/2...h-install.html
Old Oct 26, 2010 | 10:22 AM
KidShalene's Avatar
KidShalene
https://www.ford-trucks.com/forums/905477-bear-claw-latches-original-door-handles.html
https://www.ford-trucks.com/forums/296420-bearclaw-latch-install.html
I found nothing pertaining to my question searching on ** "POWER" ** bear claw latches (ones w/attached pulls), I think they are relatively new, heance I posted the question.
I believe the question is still relevant.
Old Oct 26, 2010 | 11:16 AM
CharlieLed's Avatar
CharlieLed
The simple answer is that "it all depends". There are various latches available on the market today, some have an integrated solenoid and some do not. If you buy one with an integrated solenoid then you are confining yourself to an installation that must make room for this device. However, most all Altman style latches being sold today are cable activated...which means that you can run a cable to them from a number of locations within the confines of the door cavity. I have personal experience with the Altman latches and find them VERY well constructed with a double latching mechanism. Check out Midfifty catalog page 85 for a more detailed description if you like.
Old Oct 26, 2010 | 11:58 AM
sdetweil's Avatar
sdetweil
here is a link to my installation of door pulls..
https://www.ford-trucks.com/forums/8...ml#post7026520
based on the shape of our doors, I can't image a latch with built in pull really working.
sam
Stephen67
May 29, 2017 12:49 PM
quick52
Apr 5, 2017 06:02 PM
olguy317
23
Nov 25, 2016 07:29 PM
thepitshop
22
Nov 17, 2010 12:17 PM
svooom
Jul 13, 2006 01:58 PM
