Sponsored by: Auxito
Drivetrain vibration
Old Aug 31, 2010 | 11:47 AM
scg04630's Avatar
scg04630
I have a 2000 F150 4x4, 5.4L and when I am coasting at 70 mph I get a vibration from the rear. I also get a strong vibration when I turn from a stop, mostly when I am towing. The u-joints have been replaced atleast once that I know of. I am not sure if I have the limited slip in the diff or not. What could this be from.
Old Aug 31, 2010 | 11:52 AM
1975IH200's Avatar
1975IH200
worn U-joints, worn slip yoke splines, bent or dented drive shaft, loose leaf spring u-bolts, worn shackle bolts, worn ring & pinion gears, worn rear axle bearings,....
Old Aug 31, 2010 | 01:11 PM
SteevenH's Avatar
SteevenH
Probably worn clutch pack in rearend if limited slip. Which I imagine is what you have. Vibration when turning left and accelerating is sure sign of this. You might try changing the diff. fluid and adding the friction modifier as called for. If the clutches aren't too badly worn this should
eliminate the vibration.
Old Aug 31, 2010 | 09:51 PM
steve(ill)'s Avatar
steve(ill)
clutch dont work at 70 MPH in a straight line. could be a variety of things, but tires are the first place to look. Change out the back with a spare set, or switch front and rear and see if location of vibration changes.
Old Sep 1, 2010 | 09:43 AM
SteevenH's Avatar
SteevenH
Tires wouldn't cause a strong vibration when turning . He also stated that it's worse when turning and towing . That's a classic sign of a worn clutch pack. I would also check the axle bearings for that high speed vibration. When did you last change the fluid? Is it low?
Old Sep 6, 2010 | 11:35 PM
scg04630's Avatar
scg04630
I just bought the truck bout a month ago, and just changed the fluid this past weekend. Everything inside looked clean and gears were in excellent condition. We'll see what happens.
caedo
24
May 22, 2014 06:54 AM
f1barry
Nov 21, 2008 12:58 PM
BroncoBoss351
1978 - 1996 Big Bronco
Nov 28, 2005 01:32 AM
lt6124x4
Jul 26, 2005 07:39 PM
ham4ever
Dec 9, 2004 09:38 AM
