I am on my way from Minneapolis to SiouxFalls and I am experiencing a very bad vibration. When my foot is just on the throttle. When I am accelerating no vibration and when I am coasting no vibration. vibration gets worst with speed. I need to get home for graduation tonight, what do I do?
It is definitely a vibration/rattle, it is kinda like a grinding almost. i am pretty sure it is the drive shaft but it got bad really fast. I am just worried it is something in the differential. I opened the fill plug on the differential and the fluid was very runny and brown is this normal? the diff was very hot as well, but that is not too surprising. because i am driving on the interstate. should the diff be that hot? What color should the fluid be? and What should the fluid level be?(I had to stick my finger down in the hole to check the fluid)
Get under it and start cranking on the drive shaft. If you can block the tires and put it in N. Turn the rear shaft and see if it wiggles around forcefully.
Check your U joint straps (especially your rear) for firmness of the bolts.
My rear had straps that had to be replaced and the yokes peened because it was worn due to poor installation that bellowed them out.
Had exactly the same symptoms. On throttle and off throttle no vibe. Cruising, it made a milkshake at 65 plus.
Hope it helps.
I did have to get a new diff yoke because it kept recurring even with new u-joints.
LS diff. I can't really do anything about any of that right now no matter what it is, I will just have to keep driving till i get home and hope it doesn't get any worse. I hope it is just something minor relating to the driveshafts and not the diff. Well see though i guess. Thanks
I won't drive around with even a slight thought that my U-joints are going bad. I've seen some nasty carnage from a blown U-joint. It only takes a second to crawl underneath to take a look.
Yeah....way too much. Chances are the u-joints are toast too. They looked fine on the truck, but when I pulled the drive shaft off they needle bearing were falling out around the caps, and had way too much play as well.
