General Diesel Discussion
Electric Start?
Old Aug 30, 2010 | 08:40 PM
Lavern's Avatar
Lavern
Electric Start?
I've been looking around about electric start on my 04 f250. I have to get up early for work every morning and I only live 5min away but I like to warm my truck up in our -30 winters before I leave but I like all the sleep I can get too. Can this been done to work with the glow plugs and such? Thanks for any help in advanced....
Old Oct 13, 2010 | 07:45 PM
sandmanf250's Avatar
sandmanf250
sleeping late
put a timer on your block heater and set it for about 3 hrs before you drive it. use 5w 40 rotella oil.put diesel service silver 4 ozs and 4 ozs of wally world synthetic 2 stroke oil per tank.
Old Oct 14, 2010 | 07:45 AM
Lavern's Avatar
Lavern
Probably be the cheaper route. Thanks
Old Oct 16, 2010 | 12:42 AM
nitrogen's Avatar
nitrogen
a ceramic heater makes an excellent safe car warmer. prob best to have 2 timers to handle the block heater and the car warmer. if you start with a warm cab it will prob stay warm til the engine is putting out heat. plus no chipping snow and ice off the windows and no fogging inside. the ceramic is safe because the element can only come up to a certain temp(low enough not to melt or burn stuff). due to the materials the elements resistance increases as it warms up which reduces the flow of electricity. the only way it can fail is if it burned out in which case your cab would be cold.
Old Oct 16, 2010 | 04:13 AM
Lavern's Avatar
Lavern
Yes they are the best.I have one in my big truck Just incase of heater failure.
Old Oct 16, 2010 | 05:39 AM
Lazy K's Avatar
Lazy K
Plenty of aftermarket remote start kits that will work with diesels. They cycle the glow plugs before starting. Around $70.00, more if you want an eleborate alarm system as well.
Ford do a kit as well.
Old Oct 22, 2010 | 01:09 PM
cjc951's Avatar
cjc951
I use a TRC Alarm remote starter on my 150... my buddy has it on his 2008 Twin trubo Diesel works great! You can set the remote timer for x amount of mins
Old Oct 22, 2010 | 06:07 PM
Lavern's Avatar
Lavern
I'm gonna look into that. Thanks.
tommy curtiss
Aug 9, 2016 04:30 PM
7.3stroker2
Aug 1, 2015 06:00 PM
TahoeTruckee
Aug 14, 2014 12:13 PM
WVUDPM
15
Nov 30, 2013 07:16 AM
tHeCoS
1978 - 1996 Big Bronco
Oct 21, 2004 12:08 PM
