Electrical Gremlins
Old Nov 29, 2013 | 11:10 AM
WVUDPM's Avatar
WVUDPM
Electrical Gremlins
Hey all,
I am in the process of putting my 78 back together and I have come across some electrical complications. I had it started about a year ago and it was running great but haven't since been able to work on it until now. It gets power to everything.. radio, fuel pump, etc. but no crank or starter clicking at all. I just bought a new starter and solenoid to eliminate those variables. Can anyone help me thru getting her started? I am moving soon and need to get her started again. Thanks in advance
Old Nov 29, 2013 | 11:13 AM
fmc400's Avatar
fmc400
MSEE
Pull the wire off the 'S' terminal of the starter solenoid (RED with BLUE stripe wire), and measure the voltage at this wire while a friend holds the key in START. Report your results.
Old Nov 29, 2013 | 12:17 PM
WVUDPM's Avatar
WVUDPM
I am in the process of getting a voltmeter now however when I cross the 2 small solenoid pegs there is still no cranking.
Old Nov 29, 2013 | 01:17 PM
fmc400's Avatar
fmc400
MSEE
Nothing is supposed to happen when you do that. Only shorting the large battery-side lug to the smaller 'S' terminal should make the motor crank.
Old Nov 29, 2013 | 01:56 PM
WVUDPM's Avatar
WVUDPM
Nothing happened when I did that. It did start cranking when I connected the starter peg to postoperative battery terminal though. However I don't have any spark to the plugs
Old Nov 29, 2013 | 02:20 PM
fmc400's Avatar
fmc400
MSEE
You're saying it will crank if you jump the battery directly to the starter (dangerous by the way), but NOT crank if you jump the battery to the 'S' post? That means the solenoid is bad (new or not), or it's not grounded properly.
Old Nov 29, 2013 | 03:20 PM
WVUDPM's Avatar
WVUDPM
For sake of just being able to move it, how would you suggest going about getting the spark back?
Old Nov 29, 2013 | 04:56 PM
devino246's Avatar
devino246
...you had the key on when you were checking spark, right?
Just gotta make sure...
Old Nov 29, 2013 | 04:58 PM
WVUDPM's Avatar
WVUDPM
Yes sir/ma'am
Old Nov 29, 2013 | 06:09 PM
fmc400's Avatar
fmc400
MSEE
No spark is a different problem. If the motor isn't even cranking, you can't effectively check for spark in the first place. Leaving the key in RUN and working the coil negative terminal yourself (the only way you could have been trying to get spark in this instance) is "cheating" because it takes most of the ignition system out of the picture.
For this reason, not cranking needs to be solved first and foremost. The motor needs to be cranking under its own power. Under no circumstances do I recommend jumping the starter to the battery directly.
Note that each one of your responses diverges from the previous one. If I state instructions to address an issue only for you to make an alternative suggestion, it will only delay your path to closure.
Old Nov 29, 2013 | 06:55 PM
AK FORD GUY's Avatar
AK FORD GUY
You sir, are trying to be polite. Be careful, it's painful...
Old Nov 29, 2013 | 06:59 PM
WVUDPM's Avatar
WVUDPM
My apologies, I was trying to troubleshoot at the same time. I appreciate your patience.
I solved the no spark issue, there was an unplugged connector that was hiding. However there still is no crank unless I cross the starter and battery. I know you said not to but I couldn't help myself, she started right up though. I wont be doing it anymore, I just had to see.
Old Nov 29, 2013 | 07:12 PM
AK FORD GUY
Now try this one. It will help to determine the next step.
Old Nov 29, 2013 | 07:26 PM
WVUDPM's Avatar
WVUDPM
Will do first thing in the morning. Am I right in assuming that low to no voltage at the red/blue wire would most likely point to a bad ignition switch?
Old Nov 29, 2013 | 08:03 PM
fmc400's Avatar
fmc400
MSEE
That's correct; however, the fact that it won't crank when shorting the battery side of the solenoid to the 'S' post of the solenoid means that the solenoid won't make even if you were getting power to it. Your latest observations point to a bad or improperly grounded solenoid.
