Is this a good buy???
Not really sure if this is where this might belong, but I found a 1979 Bronco in decent condition (not fully restored but not total rust bucket either). Has a rebuilt 351C with rebuilt C6 trans, both rebuilt about 40k miles ago, basically new tires, and recovered seats. The bad is it has a cracked grille and is missing the passenger side mirror. Would $1200 be a good buy for something in this condition?
There's a little rust around the rocker panels, but not much else. It's possible that he was confused and got it mixed up with 351M. I'd have to get a better look at it, but judging by the pictures it probably doesn't have any Bondo on it. I kinda had a feeling it was a good buy, so I set up a meeting for this weekend (9/4) to have a look at it and I will report back with what I either bought or found.
Judging by the pictures he took there is a little rust in the door frames, mostly concentrated around the bottom right hand corner as you are looking at the door from the outside on both sides I believe. There is also a little patch of rust on the passenger side wheel well, but to tell you more I'd have to go look at it, which is what I'm doing this weekend.
Kinda off topic, but wouldn't the 351C and 351M look the same from the outside since the 351M used the 351C block and heads?
MarineF100
10-02-2013 05:53 AM
Shane1972
09-08-2013 04:58 AM
Highboy74
06-07-2012 11:55 PM
Ken Blythen
50
02-03-2009 12:36 AM
