Remote start?
Old Oct 28, 2010 | 08:24 PM
  #46
EpicCowlick's Avatar
EpicCowlick
PowerStroke - "the auxiliary electric heater is enabled if needed (diesel only)." How does one know if the feature is enabled or disabled? Is it possible that those who's auxiliary heat is not working is due to it not being enabled?
Old Oct 28, 2010 | 09:02 PM
  #47
F700Tank's Avatar
F700Tank
Thanks for the info. Cleared up a bunch of questions.
Old Oct 28, 2010 | 09:49 PM
  #48
PowerStrokeHD's Avatar
PowerStrokeHD
The auxiliary heater is designed to work seamlessly with the heating system, so it has no real intication as to when it is working or not. As far as "enable" in this case it would be better explained as a "call for" or a "command on" since the AHCM is not a flashable/programmable module and is technically always "enabled" if it is installed in the vehicle...
The most likely reason for the AHCM to not be working is it is not meeting one or more of the required conditions for operation...
Old Oct 28, 2010 | 09:51 PM
  #49
EpicCowlick
Right, that makes sense. I was wondering if it was switchable in the PCM. Thanks.
Old Oct 28, 2010 | 11:23 PM
  #50
sncbluegt's Avatar
sncbluegt
Wow that is exactly the information I was looking!!! Thank you soo much!!!
Old Oct 31, 2010 | 12:24 AM
  #51
capt caper's Avatar
capt caper
Holy Warmbutt Batman !!! I'll like getting in when it gets 30 below this winter. That's worth the $$$$ for the remote start..
Old Nov 24, 2010 | 03:16 PM
  #52
Sportscraft's Avatar
Sportscraft
Our weather here in Oregon has been well below the 32F mark, but no seat heaters or mirrors activated?
Old Nov 24, 2010 | 06:01 PM
  #53
jfritz_drfritz's Avatar
jfritz_drfritz
I think the seat heaters activate when on remote but that the indicator light does not come on.
Old Nov 24, 2010 | 06:06 PM
  #54
Sportscraft
Yeah after I posted I started thinking about that. And then when you put the key actually in the inginiton it probably resests itself and turns it off so you can select what you want. Our weather has been cold but not wet, so the only way for me to tell if the mirrors were on would be if I saw a light.
Old Nov 25, 2010 | 03:06 PM
  #55
RickSo's Avatar
RickSo
Hi,
It has been real cold here lately -29C & -46C with windchill. I can tell you that the seat heater comes on in the auto position or any other heater setting. Does not have to be in the auto setting. Also, really like the supplimental heater option with this weather. The outside mirrors also are on and clear very well when using the remote start.
Rick
Old Dec 3, 2010 | 12:04 PM
  #56
KeithLambert7's Avatar
KeithLambert7
Originally Posted by rdenis
My remote start does not start the seats. Maybe its a canadian thing...
I have the same problem in the lower 48 (Virginia). My Remote Start also does not start the seat heater, nor does it even heat the truck cab. Even if I leave the setting in AUTO before shutting down for the night.
It was 24 degF this am, and I could see my breath in the truck when I got in after it ran in the driveway for 10-15 minutes...
What am I doing wrong??
Old Dec 3, 2010 | 12:52 PM
  #57
Sportscraft
I've been starting mine earlier and seems to be working more like I expected. My friend questioned me why people let a vehicle run with no one in it. I think she's letting her hybrid cloud her judgment!
Old Dec 3, 2010 | 01:46 PM
  #58
mvedepo's Avatar
mvedepo
What does the EXT temp say in the truck?
Old Dec 3, 2010 | 01:53 PM
  #59
KeithLambert7
This morning Ext said 24.
Old Dec 6, 2010 | 09:43 AM
  #60
CanadianSnubber518's Avatar
CanadianSnubber518
-20F in Canada. My truck is up to room temperature within 20 minutes and the seats are warm. (15minutes with command start and 5 minutes with the key in bacause it automatically shuts off) Also, forgot to plug it in the other day and fired up like a beauty. I plan on installing a new command start next week cuz the range on the stock one is like 30 feet.
screwy
Sep 23, 2019 07:32 AM
DerekF350disel
6.7L Power Stroke Diesel
26
Dec 18, 2017 05:34 AM
tim665214
Sep 15, 2016 03:55 PM
jd350b
Jan 17, 2014 10:27 AM
tdappleman
Jan 6, 2014 01:44 PM
