Dropped Bolt from HPOP Cover
Old Jan 25, 2015 | 02:24 AM
  #46
Super Duty Service's Avatar
Super Duty Service
Former Vendor
Originally Posted by softpickle
I agree. I am considering turning the engine by hand to see if it binds anywhere to give me an idea as to where it is. I think I am pretty much down to the option of separating the tranny and engine and pulling the back plate to find it. If anyone has done this, I could use some guidance.
Just remember that if you bar over the engine,, you run the risk of binding the bolt where a magnet will not pull it out. Good luck.
Old Jan 25, 2015 | 05:54 AM
  #47
softpickle's Avatar
softpickle
Can the removal of the back plate and install of new rear main seal be done with the engine still in the truck?
Old Jan 25, 2015 | 07:12 AM
  #48
cheezit's Avatar
cheezit
Yes, I ve done it. Trans has to come out how ever.
Old Jan 25, 2015 | 07:17 AM
  #49
Shaneb75's Avatar
Shaneb75
Strokin Okie
I don't know if his truck is a 4x4 or not, but if it is, would it be easier to pull the engine?
Old Jan 25, 2015 | 07:21 AM
  #50
softpickle's Avatar
softpickle
The truck is a 4x4. I am having trouble finding articles or videos on how to remove the transmission. The best I have come across says to remove transfer case first then transmission for easier removal. But I haven't found any detailed instructions on how to properly remove the transmission.
Old Jan 25, 2015 | 07:27 AM
  #51
Shaneb75's Avatar
Shaneb75
Strokin Okie
I can't speak for the trans, but I know the engine isn't too bad to pull.
How many miles does your truck have on it?
Old Jan 25, 2015 | 07:37 AM
  #52
softpickle's Avatar
softpickle
Around 90,000
Old Jan 25, 2015 | 07:45 AM
  #53
cheezit's Avatar
cheezit
To pull the engine you need to unbolt the trans from it, So no it's not.
I have always pulled them together but I made my own bracket.
Old Jan 25, 2015 | 07:49 AM
  #54
mustang_309's Avatar
mustang_309
Around 90,000
The transmission would be far easier to remove than the engine, you have bell housing bolts, torque converter to flex plate nuts ( if this is an automatic ) cross member bolts, transmission cooling lines, shifting linkage and wiring harness and front and rear drive shafts and transmission dip stick tube. It would be much easier to handle the transmission without the transfer case attached.
Old Jan 25, 2015 | 09:00 AM
  #55
softpickle's Avatar
softpickle
Ok. That's what I was thinking. When I finally pull the rear cover, will I be able to clearly see the bolt that dropped?
Old Jan 25, 2015 | 09:02 AM
  #56
softpickle's Avatar
softpickle
Will the starter need to be removed to get the rear cover off as well?
Old Jan 25, 2015 | 09:31 AM
  #57
softpickle's Avatar
softpickle
Maybe it is just me but all this seems a little intimidating for the first time separating it.
Old Jan 25, 2015 | 09:50 AM
  #58
KDAVID1's Avatar
KDAVID1
Not just you. I hopemi never have to
2006 F350 4X4
Old Jan 25, 2015 | 09:51 AM
  #59
KDAVID1's Avatar
KDAVID1
Originally Posted by KDAVID1
Not just you. I hope i never have to
2006 F350 4X4
2006 F350 4X4
Old Jan 25, 2015 | 11:54 AM
  #60
softpickle's Avatar
softpickle
Correct me if I am wrong, but once the rear cover is removed, I should be able to see the bolt or it should drop out. Correct?
