Link Bushings
Old Sep 13, 2010 | 07:51 PM
  #31
rdct's Avatar
rdct
Originally Posted by jimzigg
the y pipe was exactly what i was worried about looking at the moog design.........
Just undo the 2 bolts holding the upper mount.
Slip the mount onto the top stud, fish the link into place, rebolt the upper mount back onto the frame then tighten your upper and lower nuts onto the MOOG studs thru the frame (upper) and the sway bar (lower).
Not an issue, just different.
  #32
jimzigg's Avatar
jimzigg
also did you torque everything up evenly? bolts on the mount to frame and end links to mounts? is there a recommended torque on these?
Old Sep 13, 2010 | 07:55 PM
  #33
rdct's Avatar
rdct
I didn't find the torque specs - still looking.
I had to use a pipe on my breaker bar for the link end bolts, so I used it the same way to tighten.
The bolts on the upper frame mount came off with brute force on the 1/2" ratchet, put it back on the same as well. I plan on undoing and retightening when I find specs, but for now I drive 8 miles a day and not over 40mph so no biggie for the short term.
Old Sep 13, 2010 | 08:19 PM
  #34
jimzigg's Avatar
jimzigg
ok thx. if you can post it up when or if you find em.........
Old Sep 14, 2010 | 06:49 PM
  #35
jimzigg's Avatar
jimzigg
Originally Posted by rdct
Here's what I got in the box
got mine today what are the little threaded things for in bag with the nuts?
Old Sep 14, 2010 | 06:56 PM
  #36
1BADRIDE's Avatar
1BADRIDE
Are you talking about the grease zerk fittings? They thread into the small hole on the back of each ball joint.
Old Sep 14, 2010 | 09:36 PM
  #37
jimzigg's Avatar
jimzigg
could be that. those little holes look like they have threads? do i need to put em in? i saw some install photos where it didnt look like they were screwed in?
Old Sep 14, 2010 | 09:43 PM
  #38
rdct's Avatar
rdct
No threads in those holes - be careful when you screw them in, make sure they're straight and don't strip.
Yes you should put them in, kind of defeats the purpose of having greaseable joints. I guess if you don't plan on maintaining them then you'd have to plug the small hole in the end caps.
3/8 wrench I think, I would put them in.
Old Sep 14, 2010 | 10:10 PM
  #39
jimzigg's Avatar
jimzigg
got it thx, i put em in. drivers side done.........
Old Sep 14, 2010 | 11:13 PM
  #40
jimzigg's Avatar
jimzigg
got the moogs in tonight. started around 830 and finished about 1045 with 1 trip to azone. not bad at all. great to have a clunkless frt end!
Old Sep 14, 2010 | 11:17 PM
  #41
jimzigg's Avatar
jimzigg
also i had a question on torque earlier. i used what was in the moog instructions of 85 ft lbs and also used a little red locktite.
Old Sep 15, 2010 | 05:49 AM
  #42
rdct's Avatar
rdct
Instructions? You mean that paper inside the box? Funny how I seem to miss that all the time. Always telling my son, "If you have to read instructions, the engineer only got 50% on his final exam". We need a Homer "doh!" face here...
Old Sep 15, 2010 | 05:57 AM
  #43
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Hows that?
Old Sep 15, 2010 | 08:48 AM
  #44
jimzigg's Avatar
jimzigg
well if it makes you feel any better they were completely useless except for that fact! thx for the help on the install much appreciated.
Old Sep 15, 2010 | 08:56 PM
  #45
rdct's Avatar
rdct
Originally Posted by sddesigns
Hows that?
Perfect! I have to save that for the many times I'll need it
lemonshindig
17
Dec 4, 2013 03:20 PM
AlbyVA
6.4L Power Stroke Diesel
Apr 25, 2013 09:39 AM
1977F1504X4AUBURN
Dec 19, 2010 07:06 PM
rbhug
Dec 1, 2010 11:11 AM
esebm
Escape & Escape Hybrid
Nov 2, 2010 09:34 AM
