Link Bushings
Old Sep 2, 2010 | 07:57 AM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
It does go through the bushing, I figured any grease was better than no grease, and I only have 72K on "Blue"!
Old Sep 4, 2010 | 10:02 AM
Helidriver's Avatar
Helidriver
Ok, got the Moogs and swaybar bushings installed. They were shot for sure but didn't fix the "creeking" problem that I'm getting at low speed and when I turn the wheel when stopped. I can feel it inder my feet and I'm almost positive it's the body bushings. Anyone changed them on an X before? They look easy enough but I've said that before and got burned.
Old Sep 7, 2010 | 06:39 AM
jdw1's Avatar
jdw1
maybe it's the springs, maybe the plastic spacer at the end of the springs is missing?
Old Sep 7, 2010 | 06:50 AM
sddesigns's Avatar
sddesigns
FTE Emeritus
I'll put my money on the body mount, the bolt goes through from under your left foot. Take up the driver door floor trim piece and pull back the carpeting and you'll find the bolt head. I just soaked them with PB Blaster before attempting to loosen them up then used a good silicone spray, if I had to do it again, I'd use Fluid Film, just used it on my boat trailer this weekend, what a difference it made. Fluid Film is a site sponsor and I am not in any way shape or form part of them, or compensated by them.
I have heard both PITA to get off and easy, so unless you have a rust belt or salt water area EX, then it should be easy!
I know a little late, but here are the links I was looking for!
https://www.ford-trucks.com/forums/8...vers-feet.html
https://www.ford-trucks.com/article/...placement.html
Old Sep 7, 2010 | 02:28 PM
Joe28443's Avatar
Joe28443
Joe28443
I am having the same problem with the creeking. And popping noises on my right side when I go over a speed bump or park in my driveway. This is all good info on what to attack first
Old Sep 10, 2010 | 06:17 PM
jdw1's Avatar
jdw1
I just installed the new Moog K80273 and K80274 end links, WOW, only had one that was making noise(2000 Ex) but i did them both after work today.
Old Sep 10, 2010 | 07:52 PM
rdct's Avatar
rdct
I wonder if creaking is different than popping?
I had what I would call 'popping', not creaking. Changed my links - problem solved.
Could creaking be more of a friction movement between the mount bushing and the surfaces it contacts?
I think it also seems to be dependant on the climate that the truck resides in - dry = mount noise vs. seasonal wet weather suffers less from mount issues?
That link goes thru lots of movement - would be my first bet for a cure most of the time.
Old Sep 10, 2010 | 08:42 PM
jimzigg's Avatar
jimzigg
do these moog links come with the rubber bushings already in em and they are just bolt up and go?
Old Sep 10, 2010 | 09:14 PM
rdct's Avatar
rdct
Here's what I got in the box
Old Sep 10, 2010 | 09:57 PM
1BADRIDE's Avatar
1BADRIDE
No bushings needed with the MOOG's. They are the links in rdct's pics above. They seem like they will be bullit proof.
Old Sep 10, 2010 | 11:09 PM
jimzigg's Avatar
jimzigg
looks like a simple install?
Old Sep 11, 2010 | 01:09 AM
Peace2Peep's Avatar
Peace2Peep
What about us 2005 Excursion guys? It looks like those model numbers are only for 2000-2004, what about the 2005...are they the same?
Old Sep 13, 2010 | 07:35 PM
  #28
rdct's Avatar
rdct
Hoping they'll be better than the Ford part that lasted less than 300 miles. I might have something else going on but hoping Moog will be better anyway.
I would say simple, but not the as simple as the Ford part.
Guess it depends on your Y pipe.
Not sure if the stock ram pipe would have cleared easier with the Moog, but the Moog definitely requires a different approach than stock. Difference being the stock has bolts that you easily slip in and out of the bushing after putting the link in place; the Moog has tie-rod type ball-socket joints that obviously can't be removed.
It forced me with my Thorley Y pipe, to remove the upper mount off the frame - easy 2 bolts - and slide the mount onto the top joint/stud of the link, then place the link in position and re-bolt.
***Don't forget to support the sway bar end before removing the original.
Oddly I don't see a Moog part number for these links beyond 2004.
Ford Excursion 4WD 2005, Moog Suspension Parts.
Isn't that the damndest thing - and I searched Advanced Auto here for a F250 2005 instead of an X in case they don't realize it went that far in production, and it still shows nothing for this link for 4wd - only 2wd.
However Rock Auto says its the same part as my 2000, but Moog doesn't show that part beyond 2004, so who's right?
$45 for the Ford part from a dealer. Wonder if anyone else has replaced on an 05?
Old Sep 13, 2010 | 07:46 PM
  #29
rdct's Avatar
rdct
forgot to add some shots of that install
  #30
jimzigg's Avatar
jimzigg
the y pipe was exactly what i was worried about looking at the moog design.........
