390 carb Trouble
Old Feb 17, 2003 | 10:22 AM
76big red's Avatar
76big red
Question 390 carb Trouble
OK! My engine put together. Sitting in truck and everything hooked up.. Only problem I am having is putting the carb on and getting linkage to line up.. I am going to have to get a carb spacer. Have couple questions for spacers..
1. Get a Spacer with water jacket?
2. What type of material?
3. Open or 4 hole? ( intake is 4)
My next problem is throttle cable. If I put linkage side of carb facing the firewall My cable pushes the wrong way. Unless I Get a longer cable and mount some brackets around to make it work.
And my kickdown linkage. It was not hooked up to the stock carb. I found it hanging under the truck wrapped up in the parking brake cable (wich was cut) . If anyone has pics of thier setup It would be helpfull.
Old Feb 19, 2003 | 07:18 PM
flatdeck 82's Avatar
flatdeck 82
Cool 390 carb Trouble
I am installing a 390-8007 on a dual port offy intake
take alook at clifford performance site for spacer
I don't know how cold a temp you want to run your engine in but the best plan is to tap into no 3 & 5 header tubes and pipe a hot air riser onto your manifold base. this will work in a lot colder weather than the water heated spacer. clifford used to sell a spacer like this.
for throttle cable I located a chev ( I know ) cable off a 96 4.3 vortec it wraps around the front of the v6 on the chev plenty long enough for my linkage.
old fords never die, they just get more fun to fix !
9d4
Oct 23, 2009 06:01 PM
1972fordf-100
Dec 18, 2008 12:19 AM
hozee4
May 19, 2008 04:09 AM
DosMas
Nov 12, 2007 03:15 PM
nitrous125
Mar 20, 2001 11:06 PM
