throtle linkage/ Cable??
Old Oct 23, 2009 | 04:24 PM
9d4's Avatar
9d4
on my 74 f 100 4x4, the accelerator linkage is metal linkage, with the tube and ball pivot(female) that go to the carb, but the hole is wasted on it so the ball stud doesn't fit. Someone was just telling me my truck should have the throttle CABLE. Is this right? I have to replace this thing and want to get it right, and wondering if i need the cable setup??
Old Oct 23, 2009 | 04:50 PM
zak8tac's Avatar
zak8tac
You should have that rod like you described.
Old Oct 23, 2009 | 06:01 PM
Jermafenser's Avatar
Jermafenser
you can convert it into cable setup if you want to. I don't see the point in doing so unless you're going with an aftermarket carburetor where the linkage doesn't pull back.
Only 1979 trucks had the cable, the older had threaded rods.
samf1
2004 - 2008 F150
13
Jul 29, 2017 11:50 AM
8-ball
Aug 21, 2013 12:10 PM
hozee4
May 19, 2008 04:09 AM
tip49
Nov 6, 2006 09:54 AM
