Sponsored by: Auxito
axle removal?
Old Aug 24, 2010 | 08:14 PM
adamax21's Avatar
adamax21
axle removal?
ive got a 1997 f150 5.4 4x4. its got the 3.55 locking diff. and i gotta leaking wheel seal. i think ill go ahead and replace them both. will i have to remove the diff cover to remove the axle? or just the 4 bolts at the ends of the axle? (it has rear drum brakes) thanks you guys!
Old Aug 24, 2010 | 08:50 PM
steve(ill)'s Avatar
steve(ill)
all ford axles that i have seen work the same way. drain the oil and take the rear cover off (same time). look at the two small planet gears on a 1 inch size small sahft. there is a small bolt that retians the shaft into the housing. take out the screw and push the 1 inch shaft out, but try not to remove the gears. look at the end of the axle shaft inside. you will see a c-clip. shove the axle in toward the center, then pull the c- clip off the shaft. go to the outside wheel area and pull the shaft out. the hard part is getting the screw out of the small shaft holding the two planel gears in place. sometimes they are loctite in and TIGHT.
230jhp
1983 - 2012 Ranger & B-Series
Mar 13, 2012 03:24 PM
jawdoc
Jul 16, 2011 09:46 PM
bigb9582
Jun 29, 2011 10:34 PM
snoozer44
1997 - 2003 F150
Oct 26, 2009 07:34 PM
fastfalcon64
Jan 23, 2005 02:32 PM
