Sponsored by: Real Truck
pulling rear axle
Old Jul 16, 2011 | 07:41 PM
jawdoc's Avatar
jawdoc
pulling rear axle
ok the diff cover is off
the clamp holding the bearing is off
Now is there a C clip and how do I remove it?
Old Jul 16, 2011 | 07:42 PM
jawdoc's Avatar
jawdoc
sorry 2008 f250
Old Jul 16, 2011 | 09:04 PM
MRUGG's Avatar
MRUGG
Take the center cap off there should be I believe 5 bolts remove them and the axle will slide straight out.
Old Jul 16, 2011 | 09:46 PM
Rongold's Avatar
Rongold
AXLE REMOVAL
Everything is done externally. Remove the hub cap. Remove the 8 bolts on the axle flange, and pull out the axle shaft. No reason to go inside the rear end assembly.
RON
smokersteve
2009 - 2014 F150
Feb 15, 2013 04:46 AM
RanDawg
Dec 19, 2002 04:53 PM
StockMan
Sep 14, 2002 10:27 AM
Ultramagdan
1997 - 2003 F150
May 21, 2002 09:04 PM
the law
Jan 2, 2002 06:27 PM
