ABS light on
Old Aug 23, 2010 | 08:20 PM
brodi3man's Avatar
brodi3man
ABS light on
in wiring a 7pin trailer harness up i had to disconnect the factory wire harness under the driverside door. When i had everything complete i started the vehicle and the ABS light was on. Is there a way for me to reset this. Im guessing its on because i disconnected the harness.
Brit
Old Aug 23, 2010 | 09:19 PM
alloro's Avatar
alloro
Can we assume you plugged the harness back together under the driver's door?
Did you try disconnecting the battery for 10 minutes?
Old Aug 23, 2010 | 09:25 PM
brodi3man's Avatar
brodi3man
Yep. I plugged them both back in. I used pin 8 off one and pin 12 off the other to wire the batter charge and reverse light wires to the 7pin harness. These wires didn't pass through beings i didn't have the factory 7pin harness.
i disconnected the batter for 20min hooked it back up started the engine. ABS light still stays on.
Being in a rush I forgot to disconnect the battery. Little mad at myself. Wondering what i shorted out.
Old Aug 23, 2010 | 09:29 PM
alloro's Avatar
alloro
Do your brake lights work?
Is your e-brake on?
Any blown fuses?
Old Aug 23, 2010 | 09:52 PM
brodi3man's Avatar
brodi3man
brakes lights work
e-brake is off. i set it and reset it to make sure it wasn't partlially engaged.
I checked the ABS fuse #16 and its good. pulling it and turning the ignition to ON the brake light then stays on. put the fuse back in and key the ignition ON and the ABS lights stays but brake light goes off.
Old Aug 23, 2010 | 09:58 PM
brodi3man's Avatar
brodi3man
If anything im hoping its just the ABS sensor or the code needs cleared. I'll stop by an AutoZone or Pep Boys and see if they can run the code for me.
If anyone has the trouble shooting tech guide for ABS that'd be cool.
Old Aug 24, 2010 | 06:59 PM
brodi3man's Avatar
brodi3man
Update and Fix!
Autozone doesnt read ABS codes.
While driving to Autozone the ABS light went out and hasn't come back on. Apparently after disconnecting the rear wire harness all that is needed is a short drive for the ABS wheel sensors to reset.
adam10
Dec 9, 2013 08:00 PM
Hasher76
Sep 21, 2013 04:39 PM
GulfcoastSD
Dec 6, 2011 08:27 PM
Top Jimmy
Dec 18, 2006 08:24 PM
caddys83
Jan 22, 2006 09:06 AM
