should these be cut
Old Dec 9, 2013 | 05:17 PM
adam10's Avatar
adam10
should these be cut
I was looking tonight doing fluid check and stuff and found 2 wires cut/torn.it is 2 wire plug that goes into the harness that goes into the master cylinder harness.it is a red wire and green striped black wire.i had it in for the brake recall a while back and was wondering if maybe this was one of them that they would have disconnected or not.thereare nocodes or lights on
Old Dec 9, 2013 | 06:39 PM
F350-6's Avatar
F350-6
Can you post a picture? The recall didn't involve cutting any wires, so you should probably figure out what those wires are supposed to go to.
Old Dec 9, 2013 | 06:42 PM
adam10's Avatar
adam10
They come out of the fusible link they installed.it comes out of the front of the resovoir to a fuse.then this plug comes out of the fuse link then the wires are cut before they go out to a mess of wires up by fuse box
Old Dec 9, 2013 | 06:47 PM
adam10's Avatar
adam10
I will try to get a picture if I can figure out how to post it
Old Dec 9, 2013 | 07:20 PM
adam10's Avatar
adam10
Old Dec 9, 2013 | 07:27 PM
F350-6's Avatar
F350-6
You have to either upload it to your gallery here, or use a third party site like photobucket to upload the photo to and then attach it from there. You can't attach it directly from your computer.
The recall involved unplugging the factory connector from the master cylinder and installing the fused pigtail between the factory harness and the master cylinder. Kind of like just adding an extension cord inline.
Old Dec 9, 2013 | 07:33 PM
adam10's Avatar
adam10
I posted the picture in my album.i have the cut wires laying on top the harness
Old Dec 9, 2013 | 07:38 PM
adam10's Avatar
adam10
Old Dec 9, 2013 | 07:46 PM
F350-6's Avatar
F350-6
Need to zoom out a little bit, but it appears your cruise control recall harness is intact.
Where exactly do those cut wires lead to? Up by the firewall? Are they the pass thru wires Ford provides for wiring accessories inside the cab?
Old Dec 9, 2013 | 07:49 PM
adam10's Avatar
adam10
no they lead up to the fuse box outside.they match up color wise to the plug they are laying on top of.i have the ends going into the plug stripped and taped I was going to hook it back up but didnt know if they cut them or a critter got to them or what.
Old Dec 9, 2013 | 07:55 PM
F350-6's Avatar
F350-6
I just noticed that looks to be electrical tape on the other end of the plug you're talking about, not wires coming out the other end. My 02 doesn't have an under hood fuse box, but if no one else chimes in, I'll look at my wife's 01 tomorrow and see if the wires from that plug go to the under hood fuse box or seem to match in color.
Old Dec 9, 2013 | 08:00 PM
adam10's Avatar
adam10
Yes I taped them up.I was getting ready to reconnect them.I would appreciate it if you could.thank you
clean concepts
Dec 4, 2016 09:26 PM
Tattooed_countryboy
Electrical Systems/Wiring
Feb 18, 2008 07:02 PM
04F-250 stroked
Mar 13, 2007 06:46 PM
STGFordCrazy04
Jul 14, 2006 08:26 PM
JRM6868
Mar 2, 2006 08:13 AM
