I have been tracking down my ABS light and found that the left front wheel speed sensor has had the wiring harness ripped off from behind the front wheel. I have about 2ft of the harness coming off of the actual sensor.
Question is, since I cannot locate any wires that this seems to be able to be connected to, can I simply cut and splice these wires directly into the Tan/Black + Tan/Lt Green wires going straight to my ABS controller?
I would get the proper ford connector and pins. Just extend and fix the harness properly.
i have no idea where the wires are ripped from or need to be attached to. I see nothing. Unless someone has a picture of where it needs to be run from after the speed sensor pigtail.
Look from under the truck up behind the left rear of the inside
fender well cover. The MIA wire might or snapped back up that way.
You are also going to want a copy of this PDF. It has all the Ford Pigtails
in it so you can find the right one py looking at the photos. http://www.fordtechservice.dealercon...torcatalog.pdf
