Round EGR Cooler vs. the Square EGR Cooler
Did I read here that the round(early) EGR cooler had a failure rate which was far less than the square EGR cooler?
If not, is it true or do they both fail at about the same rate?
Would like to know as I have the round one and if it is better then maybe no EGR delete needed.
Thanks.
Thanks.
Thanks.
Thanks.
I concur with the previous posts. Mine was the square one, and when my engine oil cooler was failing (high variance between EOT & ECT) I had it replaced with the bulletproof EGR cooler. It is shame that it was not diagnosed properly when my EGR cooler failed the first time when the truck was still under warranty. It would have saved me the cost of a HPOP and Oil cooler.
I have a 2003 which has the round EGR cooler. I did a lot of research, speaking with tech's both in local dealerships and the forums. The overwhelming consensus is that the 2003 coolers are not a little bit better, but leaps and bounds better than the square design. The bottom line is if you have a round cooler, there is really no need to remove it to prevent a problem. Many of the tech's I spoke with said that they NEVER saw a 2003 EGR cooler fail, some saw less than 3. This doesn't mean that they can't fail it simply means that with the round EGR cooler it's unlikely that you will have a failure.
The argument is just delete it anyway then you are 100% assured that it wont fail, which of course is correct. Ultimately it's your decision, but when making the decision keep in mind that emissions testing will only get tougher and the EGR system is federally mandated equipment. Additionally the engine was designed around the EGR system removing it will alter the design, some think for the better some think for the worse. I kept mine more or less that I wouldn't have any hassle with emissions testing in the future.
This in NO WAY means that it's okay to run with a plugged up oil cooler though. If your coolant / oil temperatures are not within 15 degrees, you need to replace that oil cooler regardless of the type ore even presence of your EGR cooler. Remember oil runs this engine, not just lubricates it so anything that is oil related is so critical to keep within the design tolerances.
It's my understanding that you can easily fit a 2003 round EGR cooler into your later models by changing the EGR cooler and up-pipe. I don't believe that the intake needs to be changed but I have never done this so I really don't know.
