trans mount
Old Aug 23, 2010 | 06:31 PM
powerstroker100's Avatar
powerstroker100
trans mount
The bolts on the transmission mount that go into the crossmember are lose how do I tighten them? I try to snug them up and they just spin, whats the deal, I never did replace my trans mount but can they also be "worn" even if that rubber isnt cracked?
Old Aug 23, 2010 | 08:46 PM
nwebbe1079's Avatar
nwebbe1079
id have to look again but im pretty sure i was able too get a wrench on the top of mine (maybe its different) ill look tommorow. I do have to check all the other bolts on the crossmember every so often cause they rattle loose no mater how much i tighten em. I just doubled up nuts on all the ones i could reach ( i know thats not your question, but it was something i ran into when i replaced my tranny)
Old Aug 23, 2010 | 08:55 PM
tecgod13's Avatar
tecgod13
On my '88, the bottom bolts that go through the crossmember are studs, nuts go on them to hold the mount in place. There are holes in the top that bolts go through that screw into the tranny.
I'd say if you try tightening the bottom nuts, and the studs spin, its probably messed up. If the bolts that go up into the tranny are spinning, get a longer bolt and put a nut on top to hold it tight.
Old Aug 23, 2010 | 08:57 PM
powerstroker100
thanks for your post, yeah the bolts on the top of the transmission mount that go into the transmission have bolt heads on them I think they were somewhere around 18mm I cant remember, but the bottom part of the mount where the bolt holes go into the cross there is no head on them they are carriage bolts so I cant grab them, but the nuts that are on them are loose, I can turn the hole entire carriage bolt assembly it just keeps rounding out, also again if anyone knows can they be worn out even though they are not cracked? if its fine its not $20 I want to spend, the steering wheel vibrations are gone but I do have a floorboard one that I have learned to live with
Old Aug 23, 2010 | 09:04 PM
poocher pup's Avatar
poocher pup
they have probally been overtightened at some time, no real way to fix but to replace with new rubber mount, know thats not whatm you wanted to hear.
Old Aug 23, 2010 | 09:13 PM
powerstroker100
damn, well atleast I feel better knowing I have to fix it, by the way does anyone know the what size the 12 point bolts are on the yoke holding the front driveshaft, I'm almost positive 9/32" 12 point
Old Aug 23, 2010 | 09:39 PM
farmert's Avatar
farmert
The bolts that hold the ujoint on are 5/16 12 point.
Old Aug 24, 2010 | 12:50 AM
kurt5153's Avatar
kurt5153
I went for a crawl under the truck to day n noticed there's no bolts there at all n I drive it daily!!!
Old Aug 24, 2010 | 12:54 AM
powerstroker100
I drive mine daily too, the 5/16 was just a hair too big and is rounding ontop of the driveshaft bolts
tjdad62
Jan 10, 2013 09:36 AM
gtrosema
May 16, 2012 02:25 AM
RangerJamesW
Nov 24, 2007 10:06 PM
wvmudder
Engine Swaps
Oct 19, 2006 10:26 AM
tankglh21
Aug 18, 2005 02:15 AM
