6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
CEL: Code P244A and P2452
Old Aug 23, 2010 | 06:10 PM
nomorecummins's Avatar
nomorecummins
P244A: Differential Particulate filter differential pressure too low!
P2452: Diesel Particulate Filter Pressure sensor A circuit!
Took my truck off-roading yesterday, nothing too rough. Highest point I reached was probably 11,000 feet. Everything was fine, until this morning when I was headed to work. I noticed the CEL was on... I used my DPF-R to read and clear the codes. After I cleared the CEL, drove the truck around for awhile and no more CEL. Anybody have an idea on why those codes came up?
Truck has the DPF/CAT delete and I am using the DPF-R programmer!!!
Thanks alot!!!
CJ
Old Aug 23, 2010 | 06:50 PM
senix's Avatar
senix
The reason for the code is going to be your programmer most likely.
P2452 I don't know what the is..but I am sure it is going to be along the same line as the other.
This has to do with the regen's. Your programmer I assume is trying to fool the PCM that is does not need to regen, but it is not doing its job.
Eventually it may throw your truck in limp mode.
Old Aug 23, 2010 | 07:00 PM
nomorecummins
Thanks!!!! I hope it's just a fluke, but only time will tell.. If my truck goes into limp mode, then its time to get a Spartan...
Old Aug 23, 2010 | 07:32 PM
nomorecummins
So I am reading the DPF-R manual again, and it state's to place all sensors back into the exhaust "Except" the pressure sensor? So I got underneath my truck and the pressure sensor is installed in the DPF/CAT delete pipe because there was a bung for it. Was I supposed to leave it hanging out and put a plug in the pressure sensor bung? I have had the DPF-R installed for almost 4 months and this is the first time I have had a CEL...
Old Aug 23, 2010 | 08:04 PM
senix's Avatar
senix
I know nothing about that system so maybe a call to thier tech line would help. Or give it a shot.
Old Aug 24, 2010 | 11:20 AM
Rouxlon02's Avatar
Rouxlon02
I just recenlty purchased an 08' F250 from my buddy and he had the DPF-R 4.0 on the truck. He took it with him to use on his new 2010. I've been saving up to get one to use on my truck and when I saw this post it made me wonder if I was going the right route with the DPF-R. I spoke with my buddy and he said he encountered those same codes with his unit. When he called DPF-R's tech line they told him he had an eariler firmware and the it was a know issue. They paid the shipping cost to have it sent back and updated the unit. He says its worked great ever since. Runs great on his 2010 even. I'm pretty new to the diesel truck world so I hope this helps.
Old Aug 24, 2010 | 11:37 AM
nomorecummins
I have a 2010 and with the exception of this one CEL instance, I love the DPF-R. I have already contacted the Tech people and they are looking into it. They got back to me in a very timely manner, which I like. Like I said, I cleared the code, and nothing has come back. If I were you I would upgrade to the DPF-R 4.0 Economy. Should give you about 4 mpg's, for just a little more then the regular DPF-R 4.0.
So your buddy put back the DPF on your truck and put it back to stock using his DPF-R? Have you had any Regen problems since your truck is back to stock?
Carlos J...
Old Aug 24, 2010 | 12:46 PM
Rouxlon02's Avatar
Rouxlon02
Carlos J...
Yes when he put the 08' back to stock in unlocked the DPF-R unit and he was able it install it on his new truck. unfortunately I had to put the filter back on my 08' for now so it runs like they do with the filter on .... .
Thanks for the info on the Economy version. I will defiantly give that a look when I get ready to buy one.
Old Aug 24, 2010 | 08:22 PM
nomorecummins
You were spot on... I just got heard back from the tech's and they are going to update it for me and even pay for shipping. So I said the hell with it, and asked them to update it to the DPF-R Economy tune. So for an extra $129 bucks, the tech said that I should gain 5 mpg, maybe even more depending on how the truck is driven... I will keep you updated, and tell you how the new tune is working.. I should have it sometime next week...
CJ
Old Aug 24, 2010 | 08:25 PM
senix's Avatar
senix
At least we were able to narrow it down to a tuner issue and not a truck issue.
Hope it works well for you.
Old Aug 24, 2010 | 08:31 PM
nomorecummins
Thanks for your replies as well... At least Gearbox Z is willing to admit the glitch and fix the problem... I can live with that!!!
Hunter40
60
Apr 16, 2015 02:31 PM
hullum1
Aug 25, 2014 03:44 PM
Herlface
32
May 16, 2012 04:55 PM
radarweaver
18
Oct 27, 2010 04:19 PM
cm351f
15
Mar 3, 2009 09:50 PM
