6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
low coolant
Old Aug 23, 2010 | 02:49 PM
fg250's Avatar
fg250
low coolant
While under the hood this morning I noticed the coolant in the overflow tank is about 3-4" below the line, no obvious leaks, any ideas?
Old Aug 23, 2010 | 03:08 PM
R-T0r21on's Avatar
R-T0r21on
Can you tell if coolant has been splashed up on the underside of your hood?
Old Aug 23, 2010 | 03:18 PM
fg250's Avatar
fg250
no signs of any leaks, haven't seen any puddles under it and no leak stains anywhere that I can see.(although there's plenty you can't see just looking around.) I never knew you could pack so much clutter under the hood of a truck!
Old Aug 23, 2010 | 04:19 PM
fireman28's Avatar
fireman28
Mine is there from the dealer. From what I read, I think that the newer 09-10 trucks have a different (lower) full line on the bottle. After they did the venturi T retrofit I noticed they had it lower. I haven't added any and neither do they when it goes in for service.
Old Aug 23, 2010 | 04:41 PM
fg250's Avatar
fg250
Interesting, I never would have suspected that, thanks for the info. I'll double check with my dealer and see what they say when I go thursday for my new CAC. If their opinion varies from that I'll post it.
Old Aug 23, 2010 | 06:53 PM
senix's Avatar
senix
Key here is going to be not letting that coolant get below the lower line that feeds into the radiator and EGR coolers.
If they lower line is exposed to air...well then you get air and then you get caviatation.
So be sure of where it is.
Old Aug 24, 2010 | 09:02 AM
kiggy74's Avatar
kiggy74
So here's a question, on my 08 there is a couple of inches worth of fluid level below the low line, however the pickup hose is just below the low line. This means you might still have enough fluid in the bottle for the system, but the hose is too high on the bottle to pick any of it up. Why the heck didn't they put the pickup hose at a lower position on the bottle? If the risk of cavitation/air in the system is high, seems to me this would be a simple way to prevent any air until you can get some fluid added to the bottle.
Old Aug 24, 2010 | 10:35 AM
senix's Avatar
senix
Yup...bad design.
amd_038
Aug 20, 2011 08:03 PM
mcallister
Mar 23, 2008 06:40 AM
Ohio Bill
Dec 10, 2002 04:38 PM
JoeBob1901
1978 - 1996 Big Bronco
Oct 25, 2002 11:29 PM
georgedavila
Oct 9, 2001 06:09 PM
