I am having trouble removing my turbo on an 04 F350 dually with a 6.0 L engine. The paper work I have says it has three bolts holding it to the pedastel. I can only find two, one on each side. So could anyone tell me where the other one is?
The bolt is located in the rear of the turbo at the bottom. Spray with PB Blaster and let it set for awhile. Take a 10mm six point socket and a 6 inch extension on a rachet and get it from the top of the turbo. Its going to be tight so you may need a small cheater bar.
