Tow-Haul button blowing fuse ?
Old Aug 23, 2010 | 07:36 AM
Paul_Bonner's Avatar
Paul_Bonner
Question Tow-Haul button blowing fuse ?
I was wondering if anyone else has seen this problem -
On my 04 F-250 6.0L SD, when I press the Tow Haul button, about 50% of the time it works and the tow haul light comes on.
The other times, pressing the button kills all the dashboard lights and gauges - after checking I found that the 20A fuse in slot 45 is blowing (replaced fuse twice so far).
Does engaging tow haul activate any power-consuming load, or am I just looking for a short somewhere in the signal wiring ?
Many thanks
PB
Old Aug 23, 2010 | 08:16 AM
npccpartsman's Avatar
npccpartsman
Look for a short in the tow haul button wiring. I think they are kind of notorious for that or used to be. Blown fuse is direct power to ground somewhere. Try to find the wire color from that fuse to the switch.
Old Aug 23, 2010 | 03:35 PM
Paul_Bonner
Update : I pulled the steering wheel shroud off and disconnected the 2 pin connector to the gear lever tow-haul switch - eliminating it from the circuit. I wired up a switch direct to the 2 pin connector - it still blows the fuse. Can I assume I still need to look for a short somewhere further into the steering column ?
Thanks PB
Old Aug 23, 2010 | 04:15 PM
Cowboy65's Avatar
Cowboy65
Yes
A multi-meter can be used to determine which wire is shorted and to assist in locating the short. With power off to the circuit put the multi-meter on the resistance or continuity setting and ground one of the leads and touch the other lead to the wire in question. If you get continuity or very low resistance then the wire is shorted.
Old Aug 23, 2010 | 05:36 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Wouldn't one of the 2 wires be a ground anyway? But definitely not BOTH of them!
Old Aug 23, 2010 | 06:33 PM
69cj's Avatar
69cj
I'm not familiar with the ckt. but you cannot ground any hot wire unless there is a resistance before it such as a relay coil. Guaranteed to blow fuses and maybe more.
Nimrod
Nov 21, 2016 07:49 PM
WRABER
May 17, 2016 08:08 AM
blueheron
6.7L Power Stroke Diesel
17
Aug 30, 2015 01:57 PM
fordff
6.4L Power Stroke Diesel
Jan 21, 2011 08:03 AM
Rambo76
Sep 6, 2009 08:46 AM
