ok to run no iac valve?
i have been having a multitude of problems with the idle.
so i fabbed up a plate to go under the iac and close it off.
it seems to drive so much better now.
is it safe to do?
how much does this circuit effect fuel/air mixture? thats the only risk i was
thinking. maybe when i get the time or money i'll actually fix it but for now i just want to drive it without it.
is it safe to do?
I have had my iAC disconnected for the best part of 7 years now, and the truck hasnt missed a beat. It used to go to high idle when the clutch was pushed in, we found after a couple of hours of searching thru the codes that apparantly there was a short in the wire harness somewhere so I just disconnected and havent looked back. I raised the idle by turning the screw that says do not touch and even with the AC on which the IAC raises the idle for it was not a problem. so you can leave it in but disconnected as I have and should not have any problems.
I had an old Tempo with high idle problems. I replaced everything that that my repair manual said was the cause (sometimes twice) but the high idle problem still persisted. I gave up and wired a toggle switch to the IAC so that I could turn the IAC on to start the engine and then turn it off after things warmed up. I turned the idle up with the adjustment screw just fast enough so that it would stay running in drive. My daughter ran it that way for about 2 years with no problems at all.
Jonathan Stone
08-24-2016 04:11 PM
