ok to run no iac valve?
Old 08-22-2010, 07:16 PM
Danger_Dave's Avatar
Danger_Dave
Danger_Dave is offline
i have been having a multitude of problems with the idle.
so i fabbed up a plate to go under the iac and close it off.
it seems to drive so much better now.
is it safe to do?
how much does this circuit effect fuel/air mixture? thats the only risk i was
thinking. maybe when i get the time or money i'll actually fix it but for now i just want to drive it without it.
Old 08-22-2010, 09:14 PM
wtroger's Avatar
wtroger
wtroger is offline
Well if it will idle with the iac blocked off then that tells me you have a pretty good size vacuum leak. I would fix that and then the Iac system will work as designed.
Old 08-22-2010, 10:20 PM
Hank85713's Avatar
Hank85713
Hank85713 is offline
I have had my iAC disconnected for the best part of 7 years now, and the truck hasnt missed a beat. It used to go to high idle when the clutch was pushed in, we found after a couple of hours of searching thru the codes that apparantly there was a short in the wire harness somewhere so I just disconnected and havent looked back. I raised the idle by turning the screw that says do not touch and even with the AC on which the IAC raises the idle for it was not a problem. so you can leave it in but disconnected as I have and should not have any problems.
Old 08-23-2010, 06:40 AM
Dan Robertson's Avatar
Dan Robertson
Dan Robertson is offline
I had an old Tempo with high idle problems. I replaced everything that that my repair manual said was the cause (sometimes twice) but the high idle problem still persisted. I gave up and wired a toggle switch to the IAC so that I could turn the IAC on to start the engine and then turn it off after things warmed up. I turned the idle up with the adjustment screw just fast enough so that it would stay running in drive. My daughter ran it that way for about 2 years with no problems at all.
Old 08-23-2010, 04:42 PM
Danger_Dave
with it bypassed the idle drops to only a few hundred rpms and will die. i have the idle screw way turned up and its working real well for me. this totally rules out a vacuum leak possibility. thanks for the reply, i'm definitely never running the iac anymore.
Old 08-24-2010, 03:53 PM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
That is correct, if you disconnect or plug of the IAC, the engine should die. If it keeps running or idles high, you have a vacuum leak somewhere.
Jonathan Stone
08-24-2016 04:11 PM
Jonathan Stone
General Automotive Discussion
08-24-2016 04:10 PM
musicars
12-01-2013 05:50 PM
DaveBB
1997-2006 Expedition & Navigator
26
11-06-2013 11:41 PM
gmdattilo
Modular V10 (6.8l)
04-26-2011 09:59 AM
Quick Reply: ok to run no iac valve?
