Idling at 1500 rpms..
I have a 1994 F150 with dual tanks 4x4 5.0 and I cleaned the IAC valve due to other issues going on which that helped 100% but now my truck is idling at 1500 rpms. I haven't really run it much so could it be that my computer needs to reset itself? Maybe I should unplug iac? I also heard something about too much air getting in the holes in the tps on the butterflys? Should I take off the tps and clean it? Any help would be great.
Check the vacuum lines for leaks. Check/replace the upper intake manifold gasket if you get a chancel
Might be the spacer plate between the IAC and throttle body. I have a 1990 5.0 F150 and changed the IAC and had high Idle, it was 2000 - 1500 because the spacer plate was put on backwards, on the 5.0 the plate has holes on one edge, and the holes should face forward on mine, so that the side holes feed the large incoming port to the IAC and not the small out going IAC port on the TB. You might check yours or try it the other way, incase its flipped.
Jonathan Stone
08-24-2016 04:11 PM
Monster4rd
08-24-2016 04:09 PM
Jonathan Stone
07-22-2015 04:47 PM
