Sponsored by: Auxito
trans help
Old Aug 21, 2010 | 09:41 PM
ncshovelhead's Avatar
ncshovelhead
trans help
I have a 99 E250 van, with a 5.4 triton and a 4R70W trans. the other day i was backing up and it felt like i hit someting. ON down the road, my trans shifted from od to 3rd and back. then i was stopped, and took back off and it sounded like it was in 2 gears at once. then it killed the engine. So i got a tow home. The the TC light was flashing so i checked for a code. I got a P1747, Pres Ctrl Sol. A Circuit Shorted. there are no visable shorts on external wires. But there is trans fluid in the connector at trans. could that be the short? Or should i check the wires inside and sol.?
Rob_2T370
Jan 13, 2012 09:27 PM
Henry Ford the 8th
Aug 8, 2011 08:19 PM
ncshovelhead
Aug 30, 2010 01:18 PM
Tim Shultz
18
Feb 22, 2008 07:59 PM
fordhonda
1997 - 2003 F150
Aug 31, 2006 01:18 PM
