Pinging 4.0
Old Feb 16, 2003 | 07:29 AM
scottybarrett's Avatar
scottybarrett
Pinging 4.0
My 92 explorer pings at cruise, not under load. I've tried many of the tricks including new intake gasket, but now I'm thinking the EGR is not functioning properly. At cruise, it sounds like something "clicks" and the pinging starts. If I go WOT, the pinging stops.
I cannot find the EGR, where is it? Does the car even have one?
TIA,
Scott
Old Feb 16, 2003 | 07:12 PM
dsmith1484's Avatar
dsmith1484
Pinging 4.0
Try cleaning the MAFS
Dean
Old Feb 16, 2003 | 07:31 PM
Bob Ayers's Avatar
Bob Ayers
Pinging 4.0
Have you tried scanning for codes????
Old Feb 16, 2003 | 07:56 PM
scottybarrett
Pinging 4.0
There's no SES light, would it store a code without the light?
Old Feb 16, 2003 | 08:47 PM
Bob Ayers's Avatar
Bob Ayers
Pinging 4.0
Yes, it could have previously thrown a CEL, and the code will be
stored......
Old Feb 16, 2003 | 09:20 PM
mrshorty's Avatar
mrshorty
Pinging 4.0
The '92 doesn't have an EGR valve. The EGR didn't show up on the explorer 4.0 until '94.
As far as your pinging, in addition to cleaning the MAFS, I've heard some who get the pinging to go away by cleaning the injectors (did you look at them or have them cleaned while you were doing the intake manifold gasket?), decarbonizing the cylinders, a problem with the ECT sensor, some other vacuum leak or air intake leak. In essence, anything that can make the engine run lean can cause it to ping (the lean condition is the cause of the ping).
Good luck
Old Feb 16, 2003 | 09:33 PM
mrshorty's Avatar
mrshorty
Pinging 4.0
Good luck
Old Feb 20, 2003 | 07:13 PM
Billy177's Avatar
Billy177
Pinging 4.0
use premium fuel for a tank or two and see if it is still there after
Milwaukee1979F150
Oct 4, 2010 12:17 PM
hattrick
Dec 20, 2008 10:43 AM
MPDano
15
Nov 22, 2006 06:41 PM
e g rred
1983 - 2012 Ranger & B-Series
Sep 16, 2004 06:07 AM
e g rred
4 Cylinder Engines
Dec 11, 2003 08:28 PM
