92 Ranger dtc ?'s
Old Sep 15, 2004 | 06:36 AM
e g rred's Avatar
e g rred
92 Ranger dtc ?'s
I have a 92 Ranger with 2.3 with coil packs 5 sp manual . Last NOv. I posted a problem about engine ping at cruise speed . I have replaced egr, evr, egr position sensor, ect, and the ping continued until I decarboned with water injected thru a vaccum port according to a post on this forum . This along with installing cooler plugs ang removing octane spout has done away with pinging though I have a loss of power. I checked fuel pressure which was 22# which according to haynes is low. Now I have codes po172 rich - so I changed my air filter cleared the code and now I have a code po173 -lean . This truck has 155000 and the original cat Thanks in advance for any help
Old Sep 15, 2004 | 07:50 PM
Rockledge's Avatar
Rockledge
If you pulled the Spout connector, then your engine timing is currently stuck at base timing of 10 degrees BTDC, which would result in a considerable performance hit.
Regarding the lean code, check for air leaks, i.e., loose vacuum hoses, unsecure PCV system, etc. In addition, Your fuel pressure should be around 35-45 psi KOEO and 30-45 psi KOER, so it is ineed low which could very easily account for the lean condition. Consider a clogged fuel filter or a bad fuel pressure regulator before condemning the pump.
Old Sep 16, 2004 | 06:07 AM
e g rred's Avatar
e g rred
Thanks , Rock for your reply . i have changed the fuel filter and checked the fpr according to the haynes book and it seemed to be o.k. . There was no fuel in the regulator.I notice cel came back on a couple of times for about 30 seconds at acceleration but went away at hy speed (55) . I will check the codes later and keep you posted. Also I'm getting a consitant 26--28 mpg which I think is ok ?? Thanks again
MPDano
15
Nov 22, 2006 06:41 PM
e g rred
4 Cylinder Engines
Dec 11, 2003 08:28 PM
steven busch
Jul 28, 2003 03:32 PM
scottybarrett
Feb 20, 2003 07:13 PM
wwalrus2
Dec 3, 2002 06:31 PM
