Sponsored by: Real Truck
Tire change/speedo question
Old Aug 19, 2010 | 07:50 PM
Sleepsafe's Avatar
Sleepsafe
If I change from stock tires to 35's on my 08 F250 does some sort of calibration need to be done to the speedometer for accuracy? And can I do it or does it need to be done at a dealers? Thanks
Old Aug 19, 2010 | 10:23 PM
snakeside's Avatar
snakeside
The dealer can usually do this, they can reprogram up 2 sizes and down 2 sizes from factory, so if you were born with 18's or bigger you are golden. Another option is ice cold auto air, they all recalibrate speedos. Lastly you could get a tuner/programmer and do it that way and add a ton of power. There's your options.
Old Aug 20, 2010 | 06:01 AM
redford's Avatar
redford
FTE Leadership Emeritus
You need the revolutions per mile of the new tires. This is the number the programmer will need.
Old Aug 20, 2010 | 09:21 AM
semperstrokin's Avatar
semperstrokin
I went from 265/70/17 to 285/75/17 (toyo m/t) and the dealer said that they were not able to recalibrate the speedo on my 2005 F250. I printed out the revolutions per mile sheet on Toyo's web site for them. fyi.. As a side question dose it due any damage to the transmission if the size is not programmed in the PCM ?
Old Aug 20, 2010 | 09:39 AM
Subsailor1127's Avatar
Subsailor1127
I was happy to see that this thread was not about wearing a "speedo".
Old Aug 20, 2010 | 09:50 AM
Sleepsafe's Avatar
Sleepsafe
NOT
Old Aug 20, 2010 | 09:52 AM
redford's Avatar
redford
Thanks for that picture.............NOT!
Old Aug 20, 2010 | 11:08 AM
dchamberlain's Avatar
dchamberlain
I used AutoEnginuity to calibrate my speedometer. It was simply a matter of programming the tire diameter into the ABS module. I don't recall how far up or down it would go, and I don't know if AE was doing some sort of conversion for me, though.
DAFBFD58
2009 - 2014 F150
Nov 4, 2013 09:47 AM
gblaz123
May 14, 2011 10:19 AM
villestrip
Nevada Chapter
Mar 21, 2011 04:52 PM
old farmer
Jul 5, 2006 09:40 PM
VISTAR Superduty
Computer Chips & Tuners
Nov 26, 2004 08:30 PM
