Great photos and follow-up. You're not the first to think the seals are too tight. The door does really "pop" open right after installation. Most folks will notice the same thing but the seals will eventually take the shape of the door and relax a bit over a couple of weeks. I'd say to leave the seals in place for a while and see if they ease up for you. If you think they're still too tight a few weeks later, you can always do as you suggest and find a smaller diameter tubing. I haven't heard of anyone actually doing that yet so you'd be the first. That's my take.
so i just read that 50ft will give you a tad bit of spare. good to know. whats a good lube to use thats not petroleum based so that no harmful effects will occur to the tubing or door seal
this santoprene stuff really has me interested. not only because it seems superior to latex and will likely outlast the vehicle, but also cause a 50' roll is 18 bucks.
check it out. Black 1/4" ID x 3/8" OD Santoprene
ok... so after further research, ive learned all about rubber, weatherstriping, and tubing. as for weatherstriping, its EPDM...heres the link EPDM rubber - Wikipedia, the free encyclopedia
so... since im trying to match the material...ive found EPDM tubing, and its fairly cheap.
im thinkin to try the epdm stuff... a 50ft roll is 13 bucks from grainger, and theres one a mile from my work (no shipping)... and if it doesnt feel right, i dont have to buy it.
You've got my interest. I think the rebound properties are what is at stake here. If the epdm returns to shape after repeated door closures and over time it looks like you might have a winner. My concern is that this is something that is fairly simple to do, but I only want to do it once, to reduce the chance of tearing my factory door seals fishing the tubing through.
