What was our original paint?
Old Aug 18, 2010 | 05:30 PM
berry1234's Avatar
berry1234
Just curious, what kind of paint used on our trucks originally? Was is acrylic enamel or lacquer enamel?
Old Aug 18, 2010 | 06:57 PM
steponit's Avatar
steponit
AutoColorLibrary - Color Chip Selection
Old Aug 18, 2010 | 07:05 PM
berry1234's Avatar
berry1234
Thanks for that. I was curious as to what type of paint-lacquer, acrylic, etc.
Old Aug 18, 2010 | 07:13 PM
steponit's Avatar
steponit
Click the link on top of the last post
Old Aug 18, 2010 | 07:19 PM
berry1234's Avatar
berry1234
I didn't see anything other than their tech sheets on the paint they sell,
Paint Type Paint Information
Acrylic Enamel Tech Sheet
Acrylic Urethane Tech Sheet
Acrylic Lacquer Tech Sheet
Urethane Basecoat Tech Sheet
Old Aug 18, 2010 | 07:33 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Paint chip sample says Alkyd Enamel.
Interesting to see "semi-gloss" for interior paint.
Josh
Old Aug 18, 2010 | 08:21 PM
steponit's Avatar
steponit
Acrylic Enamel
Acrylic Lacquer
Alkyd Enamel
Old Aug 19, 2010 | 05:06 AM
Friesian-Bronco's Avatar
Friesian-Bronco
There is something I've been wondering, was it a single stage paint or base/top/clear?
Also, thanks for the link, didn't know TCP had that info! been getting airbrush paints there, now I can get orig colors!
Old Aug 19, 2010 | 07:50 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Single stage, base coat /clear coat didn't exist for these trucks.
Old Aug 19, 2010 | 10:50 AM
berry1234's Avatar
berry1234
Originally Posted by steponit
Acrylic Enamel
Acrylic Lacquer
Alkyd Enamel
So it could have been one of these? Thanks.
Old Aug 19, 2010 | 12:32 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The original paint was definitely enamel, I don't know whether it was acrylic or alkyd (I "think" it was acrylic but not sure).
Old Aug 19, 2010 | 12:50 PM
berry1234's Avatar
berry1234
Interesting info from an autobody forum.
1924 - Spray painting was introduced and the only available material was nitrocellulose lacquer.
1929 - Alkyd enamel was introduced. It was tougher than lacquer and needed no compounding. Most manufacturers used either lacquer or enamel from this point on, depending upon availability and factory conditions.
1940 - Chrysler and Ford changed over to enamels exclusively. Metal flakes in paints were introduced by the aluminum industry.
1956 - Acrylic lacquer was popularized due to its better sheen and durability. GM went exclusively to the material.
1960s - Paints utilized chromates, lead and other heavy metal chemicals that produced durable finishes. Ford called its enamels "porcelinized" paints.
1970 - The first aftermarket polyurethane enamel, Imron, was introduced by DuPont. It utilized a two-part chemical system that was extremely durable. DuPont experimented with waterborne solvents during this period.
1978 - High solids acrylic enamel becomes the paint choice of most manufacturers. These have the advantage of requiring fewer coats.
1980 - Base/clear coats are experimented with on Lincoln Versailles
1982 - Base/clear becomes industry standard.
1987 - Water-borne primers introduced. These paints are not actually dissolved in water, but use water as the medium to help transfer the paint from the can onto the car. They took a long time to perfect at the factory level, during which many durability problems were encountered.
1989 - Water-borne base coats introduced.
1990 - Clean Air Act sets strict limits on VOC's emitted during paint applications.
1997 - Anti-chip primers become industry standard.
Old Aug 19, 2010 | 01:11 PM
steponit's Avatar
steponit
You have to post your paint code for me to tell you.
Old Aug 19, 2010 | 01:14 PM
berry1234's Avatar
berry1234
3U (8) Lt. Blue 2907 on chip page
6P (U) Cream 2790 on chip page
Thanks.
Old Aug 19, 2010 | 01:19 PM
steponit's Avatar
steponit
Acrylic Lacquer
