Upper Ball Joint Help
Old Aug 18, 2010 | 12:14 PM
quisp's Avatar
quisp
1988 F150 5.0 EFI 4X4 Lariat TTB Suspension Left side Ball joints.
I Need some direction here...
I'm Having a real Hard time getting this Upper Ball Joint to Pop out,
I removed the Castle Nut, Marked my Camber sleeve, Been diggin around underneath the Knuckle, and between the Axle housing area for a C clip,
- Nothing)
Ive been Banging on the reveresed castle Nut with a 2 pounder, and its not movin'
Everything else came off like Butter after soaking it all in the "PB Blaster" for a day,-
Anyone been here B4?
Anyone have any Pic's on this job?
Old Aug 18, 2010 | 12:21 PM
Wicked Endings's Avatar
Wicked Endings
You have two ball joints, the upper and lower...
Have you taken out the lower one yet? You are supposed to take the lower out, then the upper.
Old Aug 18, 2010 | 12:38 PM
quisp's Avatar
quisp
No I havent removed the lower yet,- Its actually the lower that is Bad,
I figured since they were both coming out id start with the closest one......that being the top)
Ok- So with the lower removed, will I be able to see if there is a c clip somewhere? whats the benefit from taking out the lower first??
Old Aug 18, 2010 | 05:08 PM
Wicked Endings
The benefit from taking out the lower first is that all of the weight is coming down on that lower ball joint, if you remove that, the top one will be able to come out easier.
Honestly, i'm in the same boat you are. I've got to get the ball joints out of the left side...
So, we'll see how each other does it and see which one works better!
Old Aug 18, 2010 | 06:50 PM
ac700wildcat's Avatar
ac700wildcat
Do you have the knuckle off the pickup, or are you trying to get the knuckle off? You will need it off to change them. Only the lower ball joint has a clip holding it in. If you are pounding on the threaded end of the ball joint to try get it out of the knuckle, you are pounding the wrong way. Both joints need to be pressed out from the grease zerk side.
Old Aug 18, 2010 | 09:18 PM
lablue96's Avatar
lablue96
i just did mine this past two weekends. if your ball joints are on the knuckle the lower joint needs to come off first and be that last one on i think it's only on late model trucks I have a 96 so that's how I did it. earlier models have the joints in the axle (according to my haynes book) and the top ball joint needs to come off first and be the last one on when they are pressed in the axle housing.
When i was trying to take the knuckle off i was alson using a two pund hammer and nothing, so I grabbed a 10 pound hammer, it worked then. if you have an autozone close by i highly recomend going and using their loan a tool, i got their ball joint press and it was a breeze pressing them out with an impact. good luck
Old Aug 18, 2010 | 09:32 PM
danr1's Avatar
danr1
- Nothing)
You're going about it right, hit that top nut/stud harder, better yet get a larger hammer. The top joint will "pop" free first then the bottom with a one or two more cracks of the hammer.
A larger hammer is a better option, get the job done with "solid" blows, fewer of them and is preferable in fact to repeated strikes with a hammer just to light for the job at hand.
Old Aug 19, 2010 | 04:56 AM
ac700wildcat
Looks my post won't help a thing if the 88's aren't the same as my 94. Looks like you have some good information now tho.
Old Aug 19, 2010 | 06:55 AM
jr32560's Avatar
jr32560
the ball joint press works wonders--I liked it so much I bought one
Old Aug 19, 2010 | 10:57 AM
alsiroc's Avatar
alsiroc
I just did this last night on my '89.
There is no c-clip on the top joint and you don't have to worry about the clip on the lower until the knuckle is off of the truck anyway.
That whole knuckle has to come off and you use a press tool to remove/reinstall the ball joints. To get the knuckle off a "pickle fork" tool comes in handy. I hit the top joint until the camber sleeve came loose then used the fork where the bottom joint attaches. The ball joint tool works great when used correctly and does u-joints too.
4caster
Feb 18, 2013 09:37 PM
WINGNUT-
1997 - 2003 F150
Oct 9, 2011 09:17 AM
quisp
Aug 16, 2010 09:57 AM
spencry25
Aug 21, 2003 02:25 AM
spencry25
Aug 19, 2003 11:01 PM
