Upper Ball Joint
Old Aug 16, 2010 | 07:02 AM
quisp's Avatar
quisp
Upper Ball Joint
88 f150 5.0 EFI 4x4 TTB top-hat Hubs.
Anyone tell me how the Upper left Balljoint comes out -or- goes in?
I cant get the old one out of the camber sleeve,- rusted scale.
is it only the Castle nut that holds in the upper??
Or Is it Held in By the Camber Sleeve? or does the Camber sleeve stay in
I have the Ball joint PRess ready, but dont want to put it on until Im sure there is nop other nuts holding this in
Any Help would be Very much appreciated
Thanx
Old Aug 16, 2010 | 07:19 AM
Lazy K's Avatar
Lazy K
I did the ball joints in my D50 a few years ago and I would think yours are the same.
Once you have the big nut off the only thing holding it would be the taper fit. The camber bush stays where it is and the ball joint should come out of it. The best thing is to use a ball joint seperator, a cheap pickle fork type works well. You can also beat on the top of the threads with a big hammer.
You will need a ball joint press to get the joint out of the knuckle but check for a snap ring first.
Old Aug 16, 2010 | 09:41 AM
quisp's Avatar
quisp
Ok, yeah Im looking for a c clip,
Never did these B4- alot of rust on the upper, hammer and chisle, archeology on the ford- So I can Bash it out with a BFhammer? ??
Then, I'll try that after I make sure theres no C clip
I have the Balljoint Press too..
Thanx !
Old Aug 16, 2010 | 09:57 AM
Lazy K's Avatar
Lazy K
With the big nut off clean as much of the rust off as you can and just check to make sure there is not a very thin nut hiding in the rust.
sg2004
Nov 8, 2010 10:15 PM
78longbed
Nov 10, 2008 06:52 AM
Olddog66
25
Jun 2, 2008 06:05 AM
1972f1004x4
General Automotive Discussion
Oct 19, 2004 08:10 PM
