1978 - 1996 Big Bronco
Edelbrock performer EFI intake work!!
Old Aug 18, 2010 | 12:10 AM
Capone's Avatar
Capone
Update on the facelift for my 88:
Currently porting/reworking my Edelbrock EFI upper intake.
1. TB opening to plenum splitter smoothing and knife-edging of the trailing edge for smoother flow.
2. Adding a large radius to the primary opening to plenum edges to smooth airflow as it transitions and reduce unwanted turbulence. This means higher air flow and lower valve lift = low end torque.
3. Enlargement of primary tube entryways, this means that the taper as it reaches the head, is there....this means increase in air velocity as the air progresses through the intake.
To do:
1. Polish the interior of the intake surfaces, this will reduce carbon and sludge buildup in the intake and make it easier to clean when it does. Since it is a dry intake, it doesn't matter of the ports are sanded and polished smooth in the plenum and upper primary areas.
2. finish the lower intake and port match it to the heads.
Pics can be seen in my profile album
Old Aug 18, 2010 | 01:23 PM
American Thunder's Avatar
American Thunder
Nice, what are you using for the porting? Dremel?
Old Aug 18, 2010 | 05:11 PM
Capone's Avatar
Capone
Using dremel and air driven da grinder with long neck carbide bits. The Dremel is being used to work the tight spots....it works well.
Scndsin
51
Oct 11, 2022 12:48 PM
Fishbowlfire
Dec 3, 2014 09:12 PM
crazyeddie
Oct 30, 2009 08:46 PM
broke77f100
Bronco II
Jun 24, 2008 09:51 AM
dvldog458
May 7, 2005 12:55 PM
