1978 - 1996 Big Bronco
drive shaft angle issues
Old Aug 18, 2010 | 11:49 AM
forddriver17's Avatar
forddriver17
i got a 79 bronco lifted 6in with dana 60 going in the front and a sterlin 1.25 in the rear already i had to shorten the drive shaft in the back to get it to fit right and i just blew the cv joint in the back is there any way to drop the tcase and could i shim the axle more the blocks thats its got have some slant to them so idk if i can put shims ontop of that or if that will be unsafe, any suggestions or things you guys have done would be much appreciated
thanks
nick
Old Aug 18, 2010 | 12:41 PM
American Thunder's Avatar
American Thunder
I have 6" suspension lift on my '78. I also have a drivetrain that's moved rearward 4 inches, making the shaft angle even worse. What I did was, I took a shaft from a newer truck, and cut it down to fit with a lathe. I used the stock joints and double cardan from a 83 bronco.(these are quite a bit bigger than my original '78 parts, but yours should already have the bigger pieces if it's a '79) But if you're using the larger rear, maybe you could find a shaft with even bigger joints and a matching huge double cardan? I'm not sure what's available for the big stuff. But of course, bigger joints and double cardan are better, assuming they don't bind.
My truck's rear housing is shimmed to bring the pinion up in line with the driveshaft. The pinion is pointed right at the t-case yoke. You should have close to zero angle on that lower joint. This way, the double cardan does the work, NOT that single lower joint. I've run mine like this for about 8000 miles now, with no failure, and no vibration, even with the torque. I think I have about a 1 or 2 degree angle on my lower joint, but under acceleration, the pinion rises slightly, bringing the angle to damn near zero.
Old Aug 18, 2010 | 12:47 PM
American Thunder
Old Aug 18, 2010 | 05:34 PM
forddriver17
ok thanks a bunch i ordered a new driveshaft thats got 1350 joints all around with a bigger cv joint so im gonna try shimmin the axle alittle more and see what happens thanks for the help
Old Aug 18, 2010 | 06:24 PM
helirich's Avatar
helirich
Thunder, I dont know if you did it on purpose, But the angle is suppose to be about 2 degrees off from pointing straight at the T-case. This allows the needle bearings to roll just a little back and forth for lubercation. Dont ya love it when a plan comes together. LOL
Old Aug 18, 2010 | 07:27 PM
American Thunder
Oh cool! I read a bunch of stuff on the subject when I was building my driveshaft, because I wanted to get it right. I didn't need to shim the rear housing, because the previous owner had already done it when he installed the Skyjacker suspension. I didn't think about it being slightly off to allow for a bit of joint movement, but that makes sense. Glad to know I luck out sometimes.
jhobbs26
Jul 25, 2013 01:30 AM
cwocg
Feb 9, 2011 10:52 PM
fordeverpower
13
Jul 24, 2008 01:25 PM
Hodgie5
Aug 12, 2004 09:50 AM
EOD
Feb 14, 2003 11:55 AM
