Bronco II Ford Bronco II
High Performance BII
Old May 22, 2008 | 05:02 PM
broke77f100's Avatar
broke77f100
First I would like to start off saying my 1987 Bronco II Eddie Bauer Edition 4x4 5 speed with 165,000 miles on it goes 110 mph. Thats triple digits in a box! Anyhow it is the original 2.9l never rebuilt and the rockers or valves are ticking in it but thats gonna be fixed soon. I port matched my upper intake plenum to the gaskets and the throttle body to the plenum. Custom Cold Air Intake. Bosch Platinum +2 plugs. Taylor Thundervolt 8.2mm wires. Accel Cap and Rotor. Accel ignition module. Accel Coil. Gutted catalytic converter with a 1' piece 2.25" pipe or maybe its 2.5" im not sure and then a Cherry Bomb Turbo Muffler and another 2' of pipe with a turn down at the end before the axle. The rear axle ratio is the factor 3.45 open diff. Anyway what I am here to ask is which headers can i actually put on it? The pacesetters i thought are only for 2wd but my truck is 4wd which only leaves me with the option of $700 fo JBA headers? My exhaust sounds amazing now but i want the increased power and flow of headers. I will also be port matching my lower intake to the heads and upper plenum as well. This little bit of porting gives a pretty noticeable change in power or at least i think it did when i ported the upper and added a cold air intake
Old Jun 1, 2008 | 10:46 AM
broke77f100
anybody have an answer for me?
Old Jun 11, 2008 | 02:11 PM
RomerB2's Avatar
RomerB2
Last I knew the JBA's were the only ones for the 4wd's.. but it's been a while since I've been in here.. or had my truck running for that matter.
Old Jun 12, 2008 | 10:38 PM
tunedin's Avatar
tunedin
Pasesetter Makes a headers for the 2.9L, cost is about $250-$300. JBA headers are good but your gonna spend over $800
Old Jun 12, 2008 | 11:51 PM
RomerB2's Avatar
RomerB2
He said he found the Pacesetters but they're for 2wd. You might check out Hedman's too, I think I remember something about them having some.
Found some 4wd Pacesetters.. try Google.
Old Jun 13, 2008 | 11:37 PM
tunedin's Avatar
tunedin
Ihave pasesetter on mine.They will work on either. Unfortinatly Headman doesn't make any
Old Jun 15, 2008 | 04:34 PM
tunedin's Avatar
tunedin
Check this website out they have both Headers and tell you what will and wont fit
88-89 Ford Ranger/Bronco II 2.9L Performance Street Headers - Pacesetter
Old Jun 24, 2008 | 09:01 AM
broke77f100
but my truck is an 87...or is that not going to matter? i dont care about the factory H pipe thats supposed to be on my truck cuz it happens to have a Y pipe for some reason so maybe it shouldnt matter. everyone says my truck is supposed to have a H but its a Y as far as it looking like a y at least
Old Jun 24, 2008 | 09:51 AM
5.0B2's Avatar
5.0B2
try Broncograveyard.com - has a section for bronco II's and carrys headers for 2x4 and 4x4.
Scndsin
51
Oct 11, 2022 12:48 PM
Trent Racer
Jul 15, 2016 08:42 AM
buzzy613
Jul 31, 2015 11:18 AM
hustler54
17
Dec 31, 2012 09:07 PM
Capone
1978 - 1996 Big Bronco
Aug 18, 2010 05:11 PM
